Pro 8110s Fuser Stripper Plate jamming.
  • Notrons
    • Apr 2016
    • 71
    Hello Everyone,
    I have a Pro 8110s with over 10 million copies, and the coating on the fuser stripper plate is starting to peal off along the edge causing a jam. I have removed the parts that are pealing and sanded down the edges. That doesn't seem to help because it looks like the paper is catching on the edge of the plate itself.
    Ricoh doesn't supply a part number for the plate, just for the whole ass'y. Does anyone have any ideas on how I can fix this stripper plate until I can find a cheaper part. Also, does anyone have a old Pro 8110s Fuser stripper plate for sale or where I can get one?
    • 37377
    Re: Pro 8110s Fuser Stripper Plate jamming.
    Are you referring to the pressure stripper? According to my parts catalog which I downloaded in May 2016, D1794107 BRACKET:STRIPPER PAWLS:PRESSURE:PEEN. Might also be D1794114 GUIDE PLATE:FUSING EXIT:LOWER.
    • Notrons
      • Apr 2016
      • 71
      Thanks, I will keep those parts in mind if a have to replace. Was able to fix it by sanding down all the sharp edges and smooth surfaces.
        • 37377
        One thing to remember is that those stripper plates are originally coated with a thin Teflon film that helps keep toner from sticking to them.
        • Notrons
          • Apr 2016
          • 71
          Was wondering what that coating was for. Going to have to keep an eye out for that and clean it more often.
          • anothertech
            • 1762
            Is it the upper or the lower stripper that you are having trouble with?
            • Notrons
              • Apr 2016
              • 71
              Upper, the coating is flaking off the stripper plate and causing paper to caught on the sharp edges. Fixed it by pealing off the loose coating and sanding down any sharp edges. Now, need to keep an eye out for any more pealing off and toner build along the plate itself.
