Looking for clarity on a MPC4503 OP PANEL FW
  • fshead
    • 2356
    HI
    I am updating a MPC4503 and the only FW I didnt do was the op panel NOP.
    My machine has D149 1490F VER 1.05
    My romdata has D150 1438J VER 1.10
    Machine gave me a warning and i looked at the FW history and no mention of a D149 WTH ver 1.05 as previous..
  • copier tech
    • 8104
    Re: Looking for clarity on a MPC4503 OP PANEL FW
    Originally posted by fshead
    HI
    What issues did you have before & after updating the firmware?
    • FrohnB
      • Jul 2017
      • 1919
      D1491490 is in the Package Firmware module. Look in Firmware History for NOP-Package. It as a breakdown of all the modules that make up the package. D1501438J is the latest individual module released.
      Omertà
        • 36868
        HI
        One of them is for the wrong region. From the Firmware History for needed versions to use SMBv2/v3 support:
        OpePanel
        Europe, China, and Taiwan model: v1.14 (D1491490Q)
        North America, Asia and Koria model: v1.10 (D1501438J)
        Since you are is the states, the ROMDATA is the correct version. Machine has firmware for the wrong region. The machine may not fully support SMBv2/v3.
          • 36868
          This is one of the reasons that I do not like the Package firmware. D1491490 is for Europe, China, and Taiwan model.
          • fshead
            • 2356
            None
            This was a lease return I have sold and need to deliver so i update all the FW b4 placing it..
            I did have an odd issue where it kept calling for a pm even though the K drum and dev are only at 190k and color at 70k .When i cked the PM settings it showed count yield for k and color drums and dev units at 0000000 meter..ODD..Doing the updates they went back to normal but machines kept wth the pm needed display.
            • fshead
              • 2356
              IT is odd because the only FW that was different was the OP PANEL one..
                • 36868
                It might be the the op panel is the only place where there is different firmware by region. I not seen if before. The only reason I found it was I decided to the Firmware History for D1491490.
                • anothertech
                  • 1756
                  That is strange that the package has a different version than the individual firmware, did Ricoh put in the wrong firmware?
                    • 36868
                    Originally posted by anothertech
                    That is strange that the package has a different vesion the the individual firmware, did Ricoh put in the wrong firmware?
                    Quite possibly the engineer who first setup the list of firmware for the package was unaware of the difference as I was that there were different regional versions.
                    • fshead
                      • 2356
                      I did not update to the correct OP PANEL FW yet as I had to pull apart the K dev unit for
                      doctor blade voids.
                      This machines keeps giving me pm needed message and the waste toner tank is empty,drums/dev are all
                      no where near pm meter...Maybe FW will correct this?
                      • sturmtrooper
                        Copier Combobulator
                        • May 2016
                        • 587
                        doctor blade voids.
                        Have you checked the PAPER pm counter? That is the one that controls the message. Individual parts ones do not. The fuser sleeve PM value will control when the "replace fusing sleeve" message comes on.
                        • fshead
                          • 2356
                          I am putting the machine back together now but I remember total count to be 197k,and I know 75%/400k
                          life would make 300k a meter id expect to see some reminder.Plus i turned the pm setting to service not user.
                          • anothertech
                            • 1756
                            I have wondered if there is a way to turn off those warning messages, haven't found a way yet.
                            • fshead
                              • 2356
                              I did the op panel update and rebuilt the K dev unit with new developer and reset pm counter afterwards..
                              A bit dumb but no message.......
