Ricoh AP 400 Printer - New Fuser says "Reset Fuser Correctly" but resets counter
  • patterson70
    • May 2010
    • 605
    Hello, went out to replace the fuser on this older but still good printer as the red light was on. After installing the new fuser (I confirmed it is the correct product number) the red light goes on and says "Install Fuser Correctly". So I triple checked and it is installed correctly. Unable to get it to work, I installed the old fuser and now the red light is off and it works. So the new Fuser reset the counter - but now I have a new fuser in the box that will not work. Has anyone seen this before? Thanks.
  • dalewb74
    • Feb 2018
    • 1167
    Re: Ricoh AP 400 Printer - New Fuser says "Reset Fuser Correctly" but resets counter
    i would return it from where you got it. they probably just rebuilt it and didn't get something just right.
    • patterson70
      • May 2010
      • 605
      Hey thanks but it was definitely OEM and not rebuilt.
      • mikadonovan
        • May 2008
        • 2931
        This may help.
        NEVER ASSUME ANYTHING
          • 37652
          If you bought it direct from Ricoh, you should be able to return it as an out of box failure. If, as you say, it is OEM and not Genuine Ricoh, good luck.
          • patterson70
            • May 2010
            • 605
            Thanks guys. The PDF was of help, but it did not answer the question as to how the new fuser reset the counter in the machine so tht the older fuser would not show the red light and "Replace Fuser" mseeage.
            This a weird problem that may have no resolution.
            Also, what I meant by OEM is that it is Genuine Ricoh, not a third party or reman.
            • mikadonovan
              • May 2008
              • 2931
              Yes it did. The fuse under the connector of the new fuser blew and reset the fuser count so the old fuser can work again. As far as the "install fuser correctly", obviously there is something wrong with it. Send it back.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                +1 for this.
                The popped fuse reset the PM message and counters and that new fuser has a separate issue.
                • patterson70
                  • May 2010
                  • 605
                  Originally posted by Oze
                  +1 for this.
                  Thanks guys. I looked at the new one extremely carefully and everything matched up. Double checked the part number. Will re-inspect again though and if I find anything I will let you know.
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    It's been a couple of years since I tackled one of these old beasts but something to look for might be whether or not the lower frame of the fuser has a "keyed slot".
                    Not sure whether the AP600 fuser would fit this but I suspect it would.
                    Ricoh would make it impossible to switch fusers between models via a keyed slot on the fuser base plate and a pin inside the machine.
                    Just me clutching at straws here
                    • davel
                      • Oct 2011
                      • 1109
                      Wasn’t the AP 600 an A3 machine?
                      check the plug on the fusers look for a jumper in a different position.
                        • 37652
                        Check the connector wiring against the point-to-point diagram. It may be partially wired for the wrong voltage. 115V fusing lamp and thermostat between pins 1&2, jumper between pins B1 and B3. 230V fusing lamp and thermostat between pins 2&3, jumper between pins B1 and B4. If either or both those sets are wrong you will get the Fuser Not Set Correctly message.
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          Yeah...now that you've said that i remember they were a HUGE fusing assy.
                          • mikadonovan
                            • May 2008
                            • 2931
                            Hey Oze, I like your axes. Just ordered me an Epi Les Paul Studio. I'm excited, can't wait to get that slab of mahogany. (sorry, off topic)
                            • Oze
                              Ricoh Fanboy
                              • Jul 2008
                              • 1663
                              Thanks mate...I DO like the Epi Studios...especially worn cherry
