Scan to email problem on MPC4503
  • fshead
    • 2376
    #16
    Re: Scan to email problem on MPC4503
    Originally posted by Kimi
    Try starting from scratch and see how that goes.
    Ricoh Printers - SMTP2GO - just in case you are not getting the correct settings, port 2525 always works for me, 25 didnt
    Its always worth creating an account on SMTP2go or Gmail for troubleshooting, that way you know what the email/password is.
    hi
    I am testing a mpc401 in shop now
    1st will try smtp.gmail.com.
    email and password
    465
    ssl on
    dns
    8 8 8 8
    8 8 4 4 and both tested ok.
    I USEDed donontreply @anywhere.com for admin email.
      • 37495
      #17
      Originally posted by fshead
      hi
      email and password
      465
      ssl on
      dns
      8 8 8 8
      I believe C5403 supports TLS which is required by smtp.gmail.com. Proper port for TLS is 587. I don't know about your C401 in your office. It may only support SSL. There is also smtp-relay.gmail.com which supports both TLS and SSL. It also allows port 25.
      I am assuming that what you gave as the admin email is not what you actually but just to show something without private email information.
      • fshead
        • 2376
        #18
        yes on the email for admin
        I did connect the mpc401sr and it worked w/out a hitch.......
        When it s good it is good ..
        and bad well we all know....
        It just kills ones week when you spend a few hours doing IT stuff for free
          • 37495
          #19
          If they don't have their own IT, talk to them about an IT contract.
          • skinnyb
            • Jul 2008
            • 291
            #20
            Used to do that a lot. New policies in effect make this type of work billable over and above typical maintenence contract where I work.
            Sent from my LM-V405 using Tapatalk
            • fshead
              • 2376
              #21
              Thanks All
              This customer like many others are of the mindset that once something"scan to email" was working that it should always be working
              and blame myself or the machine. This is a good account so I accept somethings i dont like.
              If I had time I would consider taking some online network support courses.
                • 30222
                #22
                Thanks All
                Think of the copier as there new employee it needs it's own email address and account.
                • StephenB
                  • Aug 2015
                  • 243
                  #23
                  I have set up many accounts with SMTP2GO, including our own.
                  You cannot use a cloud based email address for the authentication ( no gmail, hotmail etc) or it will do exactly what you describe.
                  When you set up the smtp2go, there is a dashboard showing the emails processed. log on and see what the issue is.
                  I have never had an issue in years using smtp2go, simple setup too.
                    • 30222
                    #24
                    NUTS use GMAIL ALL THE TIME!
                    PS You should ALWAYS USE THERE EMAIL and SMTP PERIOD!
                    • guitar9199
                      • Sep 2016
                      • 1100
                      #25
                      hi
                      I am going back to accnt tommrw"40 min drive each way" so i want to be ready.
                      I for some reason could not get both SMTP2GO and GMAIL to function and kept getting authentication failed.
                      I will bring my laptop,created another gmail accnt with less secure app allowed and my new SMTP2GO log in name and password.
                      I am going to try these on my mpc401 that i have in shop 1st..
                      These customer just see a button to hit 4 scanning and dont care about all the stuff that could block emails and such..
                      Authentication Failed?? That tells me either user ID or PW are incorrect. User ID with gmail is the entire email address... (Can't speak to SMTP2GO), so try logging in from the customer's location to the gmail account on a laptop and see if you can get in. if so...like previously suggested, make sure 2-step verification is OFF, and "Allow Less Secure Apps" is ON.
                      PW with Gmail IS Case Sensitive....keep that in mind.
                      • guitar9199
                        • Sep 2016
                        • 1100
                        #26
                        In a perfect world, I'd absolutely agree. Problem is, our world is NOT perfect, and most company's "I.T. Guy" is the nerdy accountant in the 4th cubicle on the left, or the Boss's nephew who "Took a computer class in High School"!! There's nothing wrong with configuring a Gmail account for a customer if they want scan to email capability, but don't have any "spare" email addresses to use. Besides, how many times have you come across a customer who has to change their password every 90 days... and on day 91 you get the "I can't scan to email" call?
                        Even if you tell them how and where to update the password in the copier when those changes happen, when they DO an update, they guy you told is no longer with the company!!
                        I PREFER setting up scan to pc, with a hidden user ID I create on the computer just for the copier (WITH the blessing of the company owner/manager of course). That user is configured to never expire, and customer can't change password. I don't get those calls anymore, unless they wiped their hard drive or got a new PC. This way they can scan to the computer, and use their desktop email to send. A lot easier to audit email from their computer, rather than being able to send right from the MFP.
                          • 30222
                          #27
                          Configure a gmail account or any other the email by YOU opens up you and company to be sued.
                          • guitar9199
                            • Sep 2016
                            • 1100
                            #28
                            That's why I have the customer do it. My momma only raised a couple of dummies, but I'm not one of them!
                            • skinnyb
                              • Jul 2008
                              • 291
                              #29
                              Yes. If I go this road, I help the customer open the account so they have skin in the game and learn a little about what is going on in the process. When I do this I am normally billing them by the hour (if it's a redo that is, new installs not so) so they are usually thankful I am giving them the info for reference in the future to keep me from having to come back and do it again.
                              • NeoMatrix
                                Senior Tech.
                                • 3513
                                #30
                                Re: Tech email account for testing.
                                You can configure a customers MFD with your own email address just for testing.
                                You can easily confirm the MFD works with your own Tech email address first.
                                Set up your own test bed gmail account. Something like the following on a gmail server.
                                To : scan2email3@gmail.com
                                Subject : test
                                The above will return and automatic response back to the senders email address.
                                The return email response confirms the MFD works with outside access to mail servers.
                                NB. Just make sure you restore the original customer email details back to the MFD before leaving.
