Scan to email problem on MPC4503
  • fshead
    • 2376
    #31
    Re: Scan to email problem on MPC4503
    thanks
    all good info..
    I went yesterday and got it working but it was odd as doing it using WIM and copying and pasting
    the gmail address and password failed when i scanned but worked when i did it from OP PANEL..
    The customer has been informed that i redid this as a favor free of charge but future issues will be billable..
    My way of how most customers see scan to email is like faxxing,just add the address/tel# and send..if only
    • fshead
      • 2376
      #32
      One other question on scan to email on a mpc4503..
      When i receive my test run to my email..it has on the email header "
      WHERE DO I FIND THE SENT FROM SHIPPING PRINTER SO I CAN CHANGE IT?
      Sent From Shipping Printer..
      AND This E-mail was sent from "RNP002673B7E02D" (MP C4503).
      Scan Date: 05.14.2019 15:46:55 (-0400)
      Queries to: donotreply@ANYWHERE.COM
      • Kimi
        • Feb 2018
        • 105
        #33
        The name is the hostname of the device.
        There are a few settings on the scanner screen and within scanner features to customise the email
        • fshead
          • 2376
          #34
          RNP002673B7E02D<<<
          I did not see anything that said "from shipping printer"
          i will look again next time out there..
          thanks
          • Kimi
            • Feb 2018
            • 105
            #35
            most likely they have programmed settings on the scanner screen, you can restore this to default and see if that resolves it.
            • NeoMatrix
              Senior Tech.
              • 3513
              #36
              Originally posted by fshead
              RNP002673B7E02D<<<
              thanks
              As I understand the issue, the customer wishes to send email from the MFD, an to identify that email as coming from the SHIPPING department of the company. I haven't worked with this model machine specifically. Below is a few ideas that may help identify the MFD origin on the email printout.
              Re. DHCP Network.
              1.)
              If your customer is using a DCHP network, you should be able to change the MFD host name from "RNP002673B7E02D" to something like "SHIPPING_PRN". If the customers network firewall/server has a host name white-list, you may need their IT to rename the MFD white-list name so the MFD can once again access the DHCP network.
              2.) The customers IT could also create a new email account for the MFD using a name like "SHIPPING_PRN@anywhere.com". Use the new email account in the MFD as the host/admin sender-receiver account. All sent email printouts will contain the senders address "SHIPPING_PRN"
              3.) Does this model MFD allow for signature text on out going mail?
              If so, maybe you could set up a signature text block with a "SHIPPING_PRN" text heading. Emails will printout with a signature block "SHIPPING_PRN"
              4.) Some other ideas, which require IT programming and email forwarding.
              Don't forget to power down the MFD to initialize the new email and network settings.
              HTH
                • 37491
                #37
                If you are referring to what I think. according to the scanner Quick Reference Guide to set subject before scanniing:
                Press [Options]
                Select [Attach Subject} and press OK
                Type the desired subject and press OK
                Press the [Escape] key
                This will set it for the next scan. To save it as the Default, before hitting [Start] press [Program] then [Save as Default] and follow on screen prompts. Note, All current scan to email settings will be saved.
                • GhostInTheMachine
                  • Feb 2010
                  • 88
                  #38
                  In WIM, go to configuration. Under Scanner send settings, there is an option for "default email subject." You can select either hostname or a manually entered text.
