MPC300 Image problem
  • anothertech
    • 1771
    #16
    Re: MPC300 Image problem
    Originally posted by Voltageza
    Hi
    The image is a PDF. I have saved it as a jpeg as well but does the same. There is other images like this also with blue sky that does the same.
    If i print the image on a MPC2004 and MPC8002 in comes out fine.
    A dirty laser will cause a line along the long edge of the page.
    ok, it's not the test original if it prints fine on MPC2004 and MPC8002
    I'd go with adjusting the fuser motor speed like was suggested to you.
    Give it a try, let us know.
    If you can't figure out how to do that, then you need to place a service call on the machine.
    • NeoMatrix
      Senior Tech.
      • 3513
      #17
      Originally posted by anothertech
      ok, it's not the test original if it prints fine on MPC2004 and MPC8002I'd go with adjusting the fuser motor speed like was suggested to you.Give it a try, let us know.If you can't figure out how to do that, then you need to place a service call on the machine.
      Are you possibly using old prerun test page copies in the paper trays?Say,high volume jamb test run copies that a tech put back into recycle bin stock?Sent via phone.
      • sandmanmac
        • 3983
        #18
        You may just have to live with it.
        There was a recent discussion about an SP C430 (Same engine) that has a similar flaw, only with magenta, that doesn't seem to have a remedy.
        You may find it interesting: Dark magenta line exactly same on 2 SPC440 and 1 SPC430 printers
        • Voltageza
          • Jun 2017
          • 71
          #19
          Test print with density at 7. Left is leading edge. All colour do the same in the same spot
