MPC300 Image problem
  • Voltageza
    • Jun 2017
    • 72
    Hi Guys
    I have tested this image on 4 MPC300s and all of them do the same. Line on the same shot. When i rotate the image 180degrees the line is gone. Another image make more of a band.
    Replaced PCU units
    Raplaced Transfer belt
    Firmware up-to-date
    Print image on other machine MPC2004 and MPC8002 the it is fine. B6FB72C7-D1E2-4967-9ABA-FBA15934C776.jpgIMG_7493.jpg
  • guitar9199
    • Sep 2016
    • 1097
    Re: MPC300 Image problem
    Is this happening when you copy, or when you print?
    When you replaced the PCU's, did you clean the laser glass?
    ...inquiring minds and all that.
    • Voltageza
      • Jun 2017
      • 72
      Hi Sorry
      Was a print job. The line is on the print short end of the page. Dirty laser will cause a line in the other direction.
      • HitMan
        • Aug 2015
        • 170
        It's the laser. The paper might be short edge but think about how it's fed out
        Sent from my SM-G930F using Tapatalk
        • HitMan
          • Aug 2015
          • 170
          What you should do is run individual colours as a test to rule out your print job causing part of the problem
            • 22702
            Is it just this one document? What file format? Have you considered the possibility that the document is corrupt? =^..^=
            • Voltageza
              • Jun 2017
              • 72
              Hi
              The image is a PDF. I have saved it as a jpeg as well but does the same. There is other images like this also with blue sky that does the same.
              If i print the image on a MPC2004 and MPC8002 in comes out fine.
              A dirty laser will cause a line along the long edge of the page.
                • 22702
                Well since it's affecting blue sky, I think that I would focus on cyan for starters. The color in your sky sample is C:82 M:49 Y:0 K:32 with the cyan varying about 6% as you scan in the feed direction.
                • Voltageza
                  • Jun 2017
                  • 72
                  I have replaced cyan dev unit and pcu. Tested it on 3 different MPC300 and they all make the same lines and banding.
                    • 22702
                    What about fuser motor speed? If the fuser is turning too slow or misaligned the paper could buckle away from the drum in the center. Is the anomalie always in the same location on the paper? =^..^=
                    • Voltageza
                      • Jun 2017
                      • 72
                      Hi
                      I have never played around with fuser motor speeds. Do you know the SP Mode for this and what you suggest i must make the value?
                      • copier tech
                        • 7931
                        If as you say the same fault happens on 4 separate printers the issue is the document surely!?
                        • Voltageza
                          • Jun 2017
                          • 72
                          Must be, but why only on the MPC300s and not on the other printers?
                            • 22702
                            Originally posted by Voltageza
                            Hi
                            Sorry, I haven't any experience with this model. =^..^=
                            • NeoMatrix
                              Senior Tech.
                              • 3514
                              Re. four different printers with the same printed page fault??The only thing common to all those is the PDF file sent to the printer. Find the scanner machine that created the PDF, clean the optics, probably service the machine. HTH sent via phone.
