Ricoh mp c5503 , 1 minute for print or copy
  • tecnomarco
    • Jul 2011
    • 213
    a greeting to all, I have a problem on a Ricoh mp c5503 .... either to print or to make a simple photocopy takes over 30 seconds ... processing for over thirty seconds ... I also updated the firmware but the results do not they are satisfactory...why?
    • 37442
    Re: Ricoh mp c5503 , 1 minute for print or copy
    Sounds reasonable for wake up from sleep and first copy time. Possible someone put a C4503 fusing unit, 4 seconds longer wake up from sleep.
    Printing can also take considerable time if the wrong driver or port are used. I have seen the WSD port take as long as 30 minutes to spool 1 page.
    • tecnomarco
      • Jul 2011
      • 213
      could it be the melting unit? I have to check !! .. but in the last few months it worked well now it has given this problem .. the drivers are the PCL6 and it is not set on the WSD port
      • anothertech
        • 1766
        Come on, it's not the melting unit, is it?
        Don't worry about the print drivers if it is also slow making a copy.
        Try cleaning the thermistors. Are the Drums, Developers, Fuser, ITB belt over due for replacement?
        Is this happening when the machine is awake and ready to go, or is it when it is in sleep mode?
        • tecnomarco
          • Jul 2011
          • 213
          the prints are perfect, when launching printing it runs for 20-30 seconds ... printing or photocopying ... on the display it writes ... print 1 minute
          but all of a sudden !!!
          • tecnomarco
            • Jul 2011
            • 213
            I must also say that when the press starts even if there are 500 copies, it prints them all at a speed of 55 cpm without interruption
              • 23003
              What media type is selected? Heavier paper requires additional warmup. =^..^=
                • 37442
                From the Product Support Guide
                Warm time: D149 16 seconds. First copy delivery time: 3.1 seconds. That's a total of 19.1 Seconds for coming out of sleep to first copy letter sized LEF to deliver to exit. This assumes paper being fed from tray 1 and no finisher.
                As cat said it will take slightly longer for heavier paper.
                • blazebusiness
                  SanDiegoCopierRepair.com
                  • 1250
                  If you are certain it indeed happens with both copies and prints------if you have another c5503, swap the fixing unit with a known good one or you could try to replace the fixing film unit. I had one unit printing slow that was finally fixed by replacing that fixing film assy.
                  If it just happens with printing try switching drivers.
                  • tecnomarco
                    • Jul 2011
                    • 213
                    Thank you for the suggestions, the paper used is the normal one, the problem is the same both in copying and in printing or with photocopier in READY state, starting copying or printing writes PROCESSING IN PROGRESS .... PRINT 1 MINUTE, the print or copy are delivered after 20-30 seconds, there are no error codes ...., I have to try to replace the fuser unit ... and I'll let you know
                    • Zeldaman
                      • Mar 2011
                      • 946
                      Hi there!
                      I agree with the other folks: wsd-driver or a broken lamp in the sleeve-roller. Try also to clean or change the thermopiles.
                      Greetings...
                      • aguatepe
                        • Jul 2015
                        • 28
                        I bet on the wrong driver. Disable the WSD port from the web configuration of the machine and verify which driver is currently using the printer.
                        • davel
                          • Oct 2011
                          • 1099
                          Read original post it it doing it on copy so drivers and port have nothing to do with it.
                            • 30078
                            Check the wall voltage! under load had a kyocera that had an issue, turn out to be power connection.
