SC720-70 on SR5060
  • mckircher
    • Sep 2011
    • 21
    SC720-70 on SR5060
    When stapling sets, the drag rollers (gathering rollers) do not come out to pull in the sets and after a few get misaligned, a jam is triggered and then the sc code. Is there an sp that enables/disables the gathering rollers when stapling or anything else I should be looking at?
    Re: SC720-70 on SR5060
    I would look a the gathering rollers.. they are there for a purpose...
    is the motor not reversing ?
    is it belt run or solenoid actuated ?
    I doubt there is SP mode to disable..but there should be one to test
    • anothertech
      • 1768
      Shouldn't you get an sc720-75 if the drag rollers where not working? What is the jam code? What's the finisher firmware Version?
        • 37484
        Are you sure the problem is that the stack rollers do not move or i s the actual problem that the ribs on the foam rollers is worn off?
