Ricoh mp301 print from memory device.
  • COPIERMAN
    • Jun 2009
    • 559
    start to look at some of my mp301 that i buy from off lease and when i try print from memory device not able. i press printer button but doesn't have the option to select [Prt. From Dev] tab. I look through user tools print feature and also service mode but didn't see where it might be turn off.
    Re: Ricoh mp301 print from memory device.
    what 'memory device' are you using?
    what port?
    did you upgrade firmware?
    • dalewb74
      • Feb 2018
      • 1157
      printing from a thumb drive what format has it been formatted to? fat32 or NTFS? what type of file are you trying to print?
      • COPIERMAN
        • Jun 2009
        • 559
        I haven't update firmware but i thought this was standard feature on this model. i look at another mp301 and that one has the tab to print from a memory device.
          Firmware can become corrupt... outdated firmware could be an issue..
          What versions do you have on both?
          Post config sheets for both working and not please
          • sandmanmac
            • 3981
            1: You need the HDD option
            2: you need to make sure it's enabled in Printer SP mode
            3: you need to understand that fairly routine issues like this have most likely been covered countless times in the forum and that you should AT LEAST try to find a solution for yourself.
            ......Coincidentally there's a similar situation right here: MP C300 print from usb drive
            and here: MP 2001SP scan to usb and print from usb problem
            and here:mp 2501 not printing from memory stick
              • 37533
              From the installation procedures for USB2.0/SD Slot, set Scan SP 1013-1 from 0 to 1 to enable the port.
              • COPIERMAN
                • Jun 2009
                • 559
                i just figure with today technology that they would come with hard drives, but i look at above answer and went to brochure and see it is an option. I should had look first sorry to waste people time.
