Ricoh Mpc 5502 developer calibration
  • kleankopy
    • Feb 2016
    • 114
    What is the correct procudure to calibrate the dv units.
    We have been just cleaning them out and installing new dv. and setting an sp to 1 for a new dv unit.
    Machine seems to run a little longer after I turn it back on, like its calibrating but not sure.
    My new tech said you need to do all this other adjustments and
    he cant remember which ones so I don't want him messing a machine up.
  • anothertech
    • 1760
    Re: Ricoh Mpc 5502 developer calibration
    The only other thing in the book is...
    If you change the development unit, do the ACC procedure.
    Execute the drum phase adjustment with SP1902-001 twice
      • 37357
      As the ACC uses the ID sensors, I would recommend cleaning them first.
      • Coptech
        worker drone
        • 460
        Go into the bottom of the 3's in SP settings and turn on manual set new unit by changing to 1. Machine will reset counts and run simulations needed.
        • fshead
          • 2360
          PM Parts SettingsBefore Removing the Old PM Parts1. Enter the SP mode.2. Output the SMC logging data with SP5-990-004.3.Set the following SPs to "1" before you turn the power off. Then, the machine will reset the PMcounters automatically. In the case of developer, the developer initialization will also be doneautomatically.4. Exit the SP mode.ItemSPDeveloperBlack: 3902-005Yellow: 3902-006Cyan: 3902-007Magenta: 3902-008Drum UnitBlack: 3902-009Yellow: 3902-010Cyan: 3902-011Magenta: 3902-012
          • copier tech
            • 8132
            The procedure is in the service manual refer to this.
