MP 9002 Smearing
  • Hoosierdaddy
    • Oct 2016
    • 182
    MP 9002 Smearing
    Copies and Prints smear. Kind of the way it would look if DV was worn out and toner would build up on drum seal edge. But DV and Drum were replaced without correcting the issue. Fuser is in good shape. Anyone see similar issues out there? Machine has approx 1 million pages on it.
    Thanks in Advance
    Hoosierdaddy
    Re: MP 9002 Smearing
    Originally posted by Hoosierdaddy
    Copies and Prints smear. Kind of the way it would look if DV was worn out and toner would build up on drum seal edge. But DV and Drum were replaced without correcting the issue. Fuser is in good shape. Anyone see similar issues out there? Machine has approx 1 million pages on it. Thanks in Advance Hoosierdaddy
    how many on the fuser?
    • copier tech
      • 8192
      Thanks in Advance
      Hoosierdaddy
      Post print example this would help us.
      • jonhiker
        • 661
        If you have cleaned and did the PM on the PCU and developer, I suggest that you rebuild the fusing unit.
        • Butrus
          • Jan 2012
          • 115
          Did you check the brush behind the drum blade and the whole toner recycling system on the drum unit?
          • davel
            • Oct 2011
            • 1107
            Replace all PM parts that are due.
            • skynetto
              • Sep 2012
              • 257
              Try to clean the frame above trasfer belt unit. Too much toner builds there and cause unfused toner to smear before paper reaches fusing unit. Worth to try.
