Ricoh mpc 3002 fuser noise
  • COPIERMAN
    • Jun 2009
    • 559
    i was wondering if there is a lube felt for lower pressure roller. when the fuser stop makes a moan noise. i pull out fuser and turn by hand and you can heard noise like the lpr roller is sticking to ufr . if making copies no noise just when goes to stop. has 177,00 copies on fuser. i will need to replace ufr assy. i see line but not in copy path.
  • GIUBOSS
    • 1437
    Re: Ricoh mpc 3002 fuser noise
    if you mean 177,000 copies, I think it is necessary to change the pressure roller, sometimes I gently smooth it with a 1000/1200 abrasive paper so that the glossy surface becomes a bit dull and therefore more adherent, obviously it is a temporary solution to the noise
    • fshead
      • 2376
      there is a lubricated felt inside the fuser sleeve that can wear/dry up etc..
      I have replaced both the sleeve and the felt"a bunch of screws on that felt and then lubricate the felt with
      the syringe lub that came wth the sleeve.
      It is important the right type of grease is used.
      • skinnyb
        • Jul 2008
        • 291
        I always replace the pressure roller with the sleeve together. Peas and carrots. At least the bearings are included on this pressure roller.
        Sent from my LM-V405 using Tapatalk
        • Zaxxon
          • 608
          Gets my vote
          Please start you post with brand, model, problem.
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            SP1-121-001/002 and 003.
            Set all 3 to zero.
            That will stop the groaning after each job.
            • COPIERMAN
              • Jun 2009
              • 559
              thanks for information will try on next visit.
