Ricoh mp2501: Dirty back on first page or after pause print (mc life 85k)
  • luca72
    • Oct 2017
    • 1791
    hello guys I have this problem, when it makes the first print the sheet on the back is dirty, the other ones are good, if I print the smc, the first is dirty behind, the others are not, during the smc printing if the machine stops a moment to think between one smc and another the sheet after the break is dirty behind.I tried to do the following without success:replaced and then put back: roller transfer, drum, charge roller, turn on sp 2996(try also cycle 1 page for test), clean glass laser, reset copy application, clean drum mass pin, check back contact hvt card, the pcu has been replaced about 10-15k prints ago, checked card connection.I looked at other similar threats, but nobody said how he solved it.p.s.per absurd I have another m p2501 in the laboratory, which I wanted to use to temporarily replace this, but when I turned it on to try it, it does the same problem LOL !!!
    "I'll be back"
    Re: Ricoh mp2501: Dirty back on first page or after pause print (mc life 85k)
    what about the fixing unit?
    • luca72
      • Oct 2017
      • 1791
      hello phill, you are always the first to answer, and for this I thank you, I bet you are referring to the carbon brush that touches the fuser roller to the side to prevent the toner from sticking, tomorrow afternoon I go armed to the teeth, I have spare parts for 20 years, all original, (my boss, pay no attention to expenses, and it is a real badass with ricoh, and being ricoh italia official storic dealers, we have prices on consumables sometimes even lower than the compatible ones, I still don't I think it is the fuser, the problem is too systematic, and then I read in other discussions of this problem that has not solved, however trying a complete new fuser is a must as it takes 4 minutes to replace it
      P.S. for those who suggest: toners and everything else are strictly original
      "I'll be back"
        • 37556
          Sometimes there can also be buildup on the pressure roller.
          1st page out can always have residue on back of page..
          It get bonded on roller..then reheated.. and xfered.
          Doesn't matter mono or color..
          ESP if fuser roller/belt is scored/worn
          • copyaction
            • Oct 2007
            • 991
            How about the developer?
            • luca72
              • Oct 2017
              • 1791
              hello slimslob, this morning I checked in our management software the history of the interventions on that matriculation, it turns out: (I remembered well) I replaced for the same problem (dirty back) the complete pcdu and the transfer roller in January on 62900 print (now 85000 ) ... it lasted a little while! ... the transfer roller was the first thing I replaced yesterday, and then I activated sp2996, but already the first print produced the defect, this afternoon I have an appointment with the customer, there let me know .... I think I'll try in sequence 1) fuser 2) blade cleaning 3) developer powder
              "I'll be back"
              • copier tech
                • 8192
                I agree.
                The PTR is the only part that can transfer toner to the rear of a print.
                Fuser would give you spots/streaks that you could rub off.
                • luca72
                  • Oct 2017
                  • 1791
                  Re: Ricoh mp2501irty back on first page or after pause print (mc life 85k) [SOLVED]
                  I agree.
                  [SOLVED] ... hello, I tried the transfer roller individually the day before, and it did it anyway, as a first test I tested the fuser blocking the MC with the sheet immediately after the register, and the dirt was already present .
                  in the end I mounted a new pcdu with a new transfer roller, and the problem disappeared immediately.
                  thanks to all those who have given me a suggestion
                  ps.sp2996 I left it active at 50 pages
                  "I'll be back"
                  • copyaction
                    • Oct 2007
                    • 991
                    yes overtoning due to worn out developer is a common cause of this. The excess toner ends up on the transfer roller.
                    • COPIERMAN
                      • Jun 2009
                      • 559
                      problem is it didn't go life of 60,000 only did 15,000 copies. Seems to be a common thing on this low end copiers. i know MP2550/3351/3352/ 3353 all seam to have same issue were they don't go the 60,000 copies. I have put in all new parts in pcu assy and same thing sometimes get life and other times not.
                      • luca72
                        • Oct 2017
                        • 1791
                        update:
                        having had some time, I started to investigate the pcdu (+/- 15k life) withdrawn by the client. trying it on a mp2501 here.
                        I discovered using other parts I have in the laboratory, that the problem was in the development unit, specifically the magnetic roller, replaced this, after some testing the problem disappeared ... strange problem!
                        "I'll be back"
