MP 6001 with exit jams
  • fshead
    • 2356
    greetings.
    I have this mp6001 that was giving random duplex jams and now it is jamming 014 as the paper exits 2/3rds out.
    It is random but i tried different paper trays and pulled the drum,cleaned the sensor near the reg roller,all fuser sensors and had recenly change LFR/UFR
    and all fuser gears.Lead edge is spot on.
    It looks like the exit motor is just stopping??
  • Brianneoe
    • May 2015
    • 318
    Re: MP 6001 with exit jams
    Check the guide plate between the fuser unit and the duplex unit. Its the one that flaps back and forth when you pull out the duplex unit. There is a pin on the shaft that keeps the guide plate snug when its in the close position. Sometimes the part that the plate meets with the pin cracks and causes the paper to misfeed on the way out.
    Good luck
      • 36833
      Is there a second sheet of paper that is just exiting the fusing unit? J014 is a lead edge fusing exit jam. Fusing exit sensors have been known to fail intermediately from prolonged exposure to heat.
      • fshead
        • 2356
        it is usually one sheet 2/3rds out,no oddities and 1-2 sheets near the transfer belt.
        if it didnt reset jam i thought bad sensor but it resets and will run..
        I never had a exit motor go bad and i am replacing this box in 24 days when i can get into the building on a
        Saturday,it s in a very busy area nr 911 museum..
        • MIKON
          • Jul 2015
          • 184
          if it has 3 mil or more i would replace the transport belt. it could also be the drum seperation claw unit.
          • fshead
            • 2356
            thanks.
            It has less than 3 mil
            Image transport belt is what you suggest?
            I am going back tommr.will pull the ITB unit and was
            wondering is there only motor for fuser and exit?
            • davel
              • Oct 2011
              • 1077
              X2 for exit sensor
              • keithxxiii
                Just a tech
                • Nov 2014
                • 468
                X3 for the exit sensor.
                BTW, does it happen on all trays? Quite odd but I had martinis giving wrong paper jam code but the culprit was the paper feed unit gears.
                Aye! Cut the crap
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  I've had this issue also, just before i lost the client due to this problem.
                  I never solved it.
                  I've tried every trick in the book (and from this site)
                  Good luck!
                  • fshead
                    • 2356
                    Originally posted by davel
                    X2 for exit sensor
                    is that the one wth the flag or a reflector type sensor?
                      • 36833
                      Flag. In fact if I remember correctly it is a reed switch with a magnet on the flag end.
                      • fshead
                        • 2356
                        thanks
                        i ve seen the flag itself go where it gets a cutout over time on some older high speed sharps.
                        • fshead
                          • 2356
                          you are correct it is the old school reed switch..
                          I am talking about the one mounted on the fuser unit itself at the entrance..
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            I have noticed significant less jams if the rear panel was disassembelt.
                            Probabely due to better air transport.
                            Even dough all filters were cleaned or replaced (very important).
                            • fshead
                              • 2356
                              I cant chance some poor secretary having her hand eaten up when she goes to grab something that might have fallen..
                              I am going back wth reed switch and transfer belt as i saw mention in GG about transfer unit could cause it.
