New problem after replacing PCU
  • rightbrained
    • Oct 2014
    • 40
    [CQ] New problem after replacing PCU
    I replaced the cyan PCU on my Lanier 525c. This did solve the original CQ issue but now there is this new issue. From this image, did I do something incorrectly or did I miss something? The white splotches also appear when printing in BW.
    This machine is a cheap Craigslist find that I need to nurse along until something better becomes available. Work is piling up and customers are getting antsy. Any help would be appreciated.
  • davel
    • Oct 2011
    • 1107
    Re: New problem after replacing PCU
    Time to spend some money, update the old beast or get a trained tech with lots of parts.
    • Polo-022
      • Sep 2007
      • 486
      Remove and check Image Transfer Belt, check Paper Transfer Unit for broken parts/missing springs also.
      • tsbservice
        Field tech
        • 8019
        Replacement of costly parts without idea what to do to solve CQ problems sounds like no-no plan.
        Your customers will be pissed for a reason. As others said move on for better choice.
        • luca72
          • Oct 2017
          • 1781
          Originally posted by rightbrained
          [ATTACH=CONFIG]43430[/ATTACH]
          hi, it would seem a problem in the ITB unit, in particular I would check the small springs and the various rollers that push the belt against the drums, and already that there are the ground laminations around the ITB
          "I'll be back"
