Ricoh MPC 300 firmware
  • ChrisG
    • Oct 2013
    • 181
    Is anyone available out there that would have a recent firmware update for this model? Have a customer who's machine has started glitching with SC670 codes and want to try this before venturing down the road of replacing boards.
    Chris
    TJL Copy
  • tufbnme
    • 493
    Re: Ricoh MPC 300 firmware
    I have it.
    • tufbnme
      • 493
      • copier tech
        • 8142
        Chris
        TJL Copy
        I have the exact same issue except its on an MP C401.
        Mine won't come to ready or accept a fw update.
        If yours is an intermittent issue manual states update firmware then replace the controller.
          • 37478
          Have you tried accessing WIM? If you can try updating System and then Engine using .rfu firmware.
          • copier tech
            • 8142
            Good shout will try but I had no LAN leds on NIC seemed dead.
            • fshead
              • 2376
              like others have chimed in I now pull all toner bottles out b4 knowing it is a true sc670.
              I dont know what the RFID brds have to do with it but have seen toner chip,dirty contacts or other
              give false alarms..
              • fshead
                • 2376
                it s odd i just had a shop machine mpc300 that took a while to show ready that coded sc670/
                I restarted it a few times and no change.
                I then took all toners out and turned back on wth front door open.
                Machine did not code again wth door open or close.
                I swapped different used toners one at a time and now it seems ok.
