MP C3503 ADF Jamming
  • ABS tect
    • Sep 2013
    • 511
    This ADF keeps jamming simply by closing the lid. When I clear the non existent jam and go to start scanning a document, it jams immediately and the way to clear it is by lifting the ADF up and back down. I read something about moving that little white slider all the way over in the ADF but that did nothing. Weird... Any thoughts?
  • copier tech
    • 8132
    Re: MP C3503 ADF Jamming
    Check the fax stamp holder position if not in the correct position this block a sensor & shows a constant jam.
    Failing that check all your sensors using input check.
    • ABS tect
      • Sep 2013
      • 511
      Sheesh I was moving the wrong part...thank you. That was it. One of those weeks
