SOP RICOH
  • JOLYNAR
    • Nov 2012
    • 44
    SOP RICOH
    Do you have any idea how to remove the operating system from the Sop ricoh and replace it with an android operating system?
  • zed255
    How'd ya manage that?
    • 1024
    Re: SOP RICOH
    Pretty sure that the SOP will only accept software with a valid developer's signature provided by Ricoh. I do not believe it will be possible to just drop on a 'normal' flavour of Android despite the SOP running on Android as the basis for Ricoh's user interface.
    The engines run on BSD and I know without those issued signatures that the units will reject modified firmware.
      • 37556
      Re: SOP RICOH
      The SOP panel already has its own android OS separate from the main frame operating system. If you were aq trained and authorized Ricoh tech,you would have already known that.
      • Coptech
        worker drone
        • 460
        Re: SOP RICOH
        What is the end goal? Did you get a junk machine and decide it was an opportunity to get a free tablet or what?
        Explain why you are wanting to change the operating system...
        • tinfox
          • 317
          Re: SOP RICOH
          It's porn. It's always porn.
          Sent from my moto e5 supra using Tapatalk
          • Coptech
            worker drone
            • 460
            Re: SOP RICOH
            The old Jackson Browne song "Rosie" comes to mind...
            • copier tech
              • 8190
              Re: SOP RICOH
              This can not be done.
              • JOLYNAR
                • Nov 2012
                • 44
                Re: SOP RICOH
                is a project for children with down syndrome
                  • 37556
                  Re: SOP RICOH
                  If you have a specific app in mind, you will need to submit it to Ricoh Solutions support for evaluation and possible incorporation into the Ricoh app library.
                  • dalewb74
                    • Feb 2018
                    • 1162
                    Re: SOP RICOH
                    since the ricoh is gonna be a project and already has a current adroid OS on it. use it as it is instead of trying to reinvent the wheel. ricoh has enough things that you can do with it or add to it to get more bells and whistles. don't think kids would be that much interested in a copier and it's functions. though i am sure they would enjoy it if you stick your hand or other objects on the platen and make copies.
                    • fshead
                      • 2376
                      Re: SOP RICOH
                      OR if not porn online gambling......................
