Replacing hard drive MP-C2003
  • campy
    • May 2012
    • 315
    Is there any software that needs to be installed when replacing the hard drive or is it just for storage?
    Re: Replacing hard drive MP-C2003
    proper procedure is in the service manual
    • campy
      • May 2012
      • 315
      I don't have a manual.
      • sandmanmac
        • 3980
        Do you honestly think you're the first one to ask about HDD replacement here? Maybe consider showing just the slightest bit of initiative and consider doing a search, and reading through some of the 500 or more discussions already on this site relating to HDD replacement on Ricoh machines
        • anothertech
          • 1766
          Just stick the new drive in, it'll be fine.
          • campy
            • May 2012
            • 315
            I searched replacing hard drive c2003 and nothing came up. I didn't do a search on generic hard drive because I am sure not all models are the same. I am not even asking for myself I am helping out someone else who has a customer that might need one. If you don't want to help just ignore the 500 who asked and don't be such a dick.
            • campy
              • May 2012
              • 315
              Thanks for the info. I guess it's too hard for others to give a quick and simple answer.
                • 37422
                Sandy did not say numerous threads for the C2003. He said for replacing the HDD. As for your question, are there any Solutions or apps currently installed on the MFP? If so, you will need any source SD cards and files. Also be aware you will lose any documents stored in document server.
                  • 37422
                  Keep that attitude and you are going to start collecting Red Cards.
                    rule #1 for ANY good tech.. get the manual
                    #2 RTFM
                    #3 google the issue
                    #4 search RICOH forum for "replace hard drive"
                    #5 don't cop a " 'tude" here,..... like Slim said it will gain you red flags..
                    yup sure will!
                      WRONG
                        well he has gotten his first...
                        all those posts and no rep power.. I don't really follow anything he has to say.. but from what I've seen not a contributor in any fashion.
                        • campy
                          • May 2012
                          • 315
                          Can someone tell me why when I searched replacing MP-C2003 hard drive nothing came up? Why didn't any post with the words replacing hard drive come up? I just did a search replacing hard drive and a lot came up so I started to read through a few and it raised more questions. I also see so many contributors with conflicting advice, so how does someone who is not that familiar with Ricoh supposed to know who is giving the right info?
                          • copier tech
                            • 8133
                            Basically as an end user you're not supposed to remove any screws.
                            Replacing the HDD should only done by a trained tech.
                            However, out of interest why are you looking to replace the drive? do you have a specific issue/error?
                            • copyaction
                              • Oct 2007
                              • 985
                              and also anything stored in the address book.
