Mpc4502 no toner magenta
  • mrfuser
    • 1617
  • davel
    • Oct 2011
    • 1099
    Re: Mpc4502 no toner magenta
    PM count on unit? Is dev unit turning? Dev on roller? Is it calling for toner, did you change tube.
      • 37429
      Damaged contacts on the toner bottle detection board or the back end of the bottle. Usually caused by the user slamming the bottle in rather than sliding it in gently. Could also be a bad chip on the bottle.
      • fshead
        • 2376
        OEM TONER?
        is the bottle empty???????
        Is unit overtoned?????????????
        did you ck the waste unit and is it top heavy wth magenta?
        • zed255
          How'd ya manage that?
          • 1024
          Originally posted by davel
          ... Is it calling for toner, did you change tube.
          +1 to this. Seen lazy guys replace the pumps and not bother to install the tube that comes with the pump, only to have the same issue shortly thereafter.
          • mikadonovan
            • May 2008
            • 2931
            +2
            NEVER ASSUME ANYTHING
            • fshead
              • 2376
              is it called a tube or a hose???????????
              I pull them out and the spring loaded piece and shoot air outside and as long as they are not torn or hard resuse them.,
              I hate swapping the danm yellow one as my fat hands dont fit and getting the danm connector back on always gives me
              fits..
              I keep meaning to make a jig but never the free time...
              • fshead
                • 2376
                • mrfuser
                  • 1617
                  Rf contact on back was completely coated. Cleaned and came to ready. Only issue is for magenta only it does not show how much is in it just shows a blank column
                  • Zaxxon
                    • 608
                    Please start you post with brand, model, problem.
                    • fshead
                      • 2376
                      OK
                      THAT SOUNDS RIGHT.....................
                      and from what i am led to believe these chips use RADIO freq to be read..........
                      Well at least you answered all the questions brought up from other techs
                        • 37429
                        Originally posted by fshead
                        OK
                        Most Ricoh use a non contact RFID system for the toner chips. For some reason they decided to use a contract system with this model. Highly susceptible to contact damage.
                        • Dan G
                          • Nov 2014
                          • 56
                          there is a little elbow that comes off the toner reservoir in the rear of the machine that will clog up. Replace rather than clean because it will return very quickly.
                          • Dan G
                            • Nov 2014
                            • 56
                            this will happen because machine is now confused somehow on which toner is installed or something . perhaps the chip gets damaged? I've seen it but machine will continue to work until btl is empty just as before
                            • keithxxiii
                              Just a tech
                              • Nov 2014
                              • 468
                              Maybe the hose has been squeezed by the transfer unit assembly after installation. There were so many holes on the back frame of the machine that techs sometimes mess up routing the hose to.
                              Aye! Cut the crap
