Mpc4502 no toner magenta
  • Mark Bbb
    • Jun 2012
    • 1662
    #16
    Re: Mpc4502 no toner magenta
    I replace the nozzle when replacing pump and vacuum the supply hose did not do the fix.
      • 37168
      #17
      The toner supply hose has a Teflon coating on the inside to help prevent clogging. Any method of cleaning WILL damage that coating and cause it to clog. That is why Ricoh started selling the pump and hose as a set.
      • mrfuser
        • 1604
        #18
        Ok, all was great for a few days and right back to same error per customer. No magenta toner. Replaced tube, pump, elbow, rfid board and cartridge. All came to ready and showed full and now right back to empty! Eh?!?!?? Any ideas?
        • MIGUELMARCHENA
          • Feb 2018
          • 189
          #19
          Well, this has happened to me
          the toner stores it standing up, not lying down, and this causes the toner to turn rocks
          total that obstructs the passage through the hose
          so
          I take out the hose, I blow it making sure the air goes well
          back clean the sensor etc
          In the toner cartridge, I open it, that is, I run the toner step, place a sheet of paper for the watering and turn the cartridge so that a bit of toner comes out, the one that is caked
          and it worked well without changing pump or hose
          • fshead
            • 2360
            #20
            maybe get a tech who does more than fusers
            • mrfuser
              • 1604
              #21
              not surprised by this stupid post by someone named fish head , go back to your teen blogs where you belong fishhead
              • fshead
                • 2360
                #22
                ITS fshead......
                2nd you are only a taker no rep and i feel not much of a tech...
                You never thank anyone nor answer "The basic questions".
                Just let us guess like the random end user that "TAKE ONLY" too
                • mrfuser
                  • 1604
                  #23
                  ok thanks fishhead 👍
                  ITS fshead......
                  • FrohnB
                    • Jul 2017
                    • 1919
                    #24
                    Replace your magenta development unit, I don't think I saw where you've tried that. Had a machine where the Vref and Vt were way out of whack and machine wouldn't recover until I replaced dev. unit.
                    Have also had new toner pumps that were bad, might not hurt to try another one.
                    Omertà
