functional problem
  • shahtech
    [Error Code] functional problem
    can any one suggest how i can fix this code SC863-15 in Ricoh copier/printer
    i try to solve other way but could not any suggetion
    thanks
  • sandmanmac
    • 3981
    Re: functional problem
    thanks
    I looked into my crystal ball and it asked me 'what the hell is the model number???!", and then it told me to 'call a tech' if I couldn't at least provide that information.
      • 37489
      Have you checked your service manual. Lacking the specific model, all I can say is start with formatting or replacing the entire HDD. Next step is to replace the controller.
      • jakebear
        • Oct 2019
        • 33
        Try changing the image board or control board
        • FrohnB
          • Jul 2017
          • 1919
          Saw this code a couple times on older machines like the Savin C3528. Ultimately had to replace HDD's.
          Omertà
          • guitar9199
            • Sep 2016
            • 1100
            Goose's Guide says SC863-15 is a HDD Read Error. You can try reformatting the drive, but if that doesn't resolve it you'll need to replace it.
              • 8144
              thanks
              Depending on what model this is & the "other way you tried to solve"
              Try disconnecting the HDD & rebooting this will help you narrow down the issue.
              • Zaxxon
                • 608
                thanks
                Other way?
                Please start you post with brand, model, problem.
