Blurred Prints/copies and B246 9510 drum does never reach target yield of 1.2m copies
  • Codex
    • May 2008
    • 704
    [CQ] Blurred Prints/copies and B246 9510 drum does never reach target yield of 1.2m copies
    Hello
    Since a few months we have weird problems with our machines. Daily service calls for the same reason "light copies or blurred prints"..... All this machines have a B246 9510 Drum.....it seems the priblem starts with approx 500k,sometimes earlier. In all this machines we changed the developer and the blade at the same time as the Drum. But if you have a look on this drums we had to change they look worn out, they look like they have 5million clicks on it......small stripes, opache areas.....(in this areas the toner during the rotation falls down causing the blurred print)....... We had a similar issue two years ago.... Turned out to be the Type9002 toner. But now it's different.... For me it seems if the toner/developer acts as a "steel brush" on the drum surface (the cleaning brushes are original and new)....... Any suggestions? Its not humidity I'm sure.... (thats what ricoh said).. The problems haloens during the day... Doesn't matter if morning... Noon... Or night.... It's not a humidity problem
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Re: Blurred Prints/copies and B246 9510 drum does never reach target yield of 1.2m co
    I use to replace the 1.2M drum with 750K drum for my 7502 and MP5500 that does 400k monthly.
    Works well because I have to replace them every after 2 months.
    I never had a martini in my mif that has reached the target yield of 1.2M. It always fails around 800k no matter how timely you replace your filters and PM parts.
    Aye! Cut the crap
    • GIUBOSS
      • 1436
      check the pm counter and follow the indicated replacements, I often replace the grid, the corona wire and sometimes the led lamp could cause connection problems as well as being dirty.
        • 37529
        Judging from the row of black spots on the first picture, someone put the drum without first coating it with either drum lubricant powder or toner. The row of black spots is where the blade stuck and flipped, damaging the drum surface.
        • MIKON
          • Jul 2015
          • 188
          I see that when it is very humid. Clean filters turn on drum and paper tray heater. Cross fingers
          • Codex
            • May 2008
            • 704
            We use always drum powder..... The drums have 500-600 clicks on it..... The problem normally appears at 400-500k.......a flipped blade creates a problem almost immediately or not?
            • Codex
              • May 2008
              • 704
              The strange thing is that sometimes its only a small part with stripes as in the first image.... Sometimes the whole drum surface is full from one side to the other side...... Is it possible that the toner, together with the brush/blade works like a kind of "steele brush"...??...... Causing this damage?
              • Polo-022
                • Sep 2007
                • 486
                If you polish the drum with Brasso cleaner, all these streaks
                and deletion effects will go away. Dust the drum with powder.
                Make sure you have both heaters connected and the customer does
                not switch off everything from the electric board. Caution here.
                Then adjust SP-3901 to 1, SP-3902-001 set to 1,
                SP-3903-001 set to 1, SP-3904 set to 2 -"Level 2".
                After all check the area if it is well ventilated.
                Usually happens where there is only a door.
                ...then..."fingers crossed" as MIKON says before!!
                • Codex
                  • May 2008
                  • 704
                  I've already done al the recommended sp settings.... I've read a german bulletin to clean the drum with lube cleaner... But it didn't work..... I'll try your brasso cleaner... Do you have any link to it?
                  • Polo-022
                    • Sep 2007
                    • 486
                    https://www.amazon.co.uk/d/Furniture-Polishes/Brasso-Metal-Polish-175-ml/B002G0BULU
                    Use a soft foam pad to polish the drum.
                    Drum polishing was a major activity a few decades
                    before.
                    • fshead
                      • 2376
                      LOOKS like you might has a real hard cleaning brush too..
                      If it isnt soft I would change brush,drum blade and pull the clear recycling tubes in front and
                      tear down and clean and then all filters.check the toner recycling unit on dev unit for mylars falling off,can be reglued on..
                      .Sometimes an undertoned developer will scratch the drum too..
                      • KeviM
                        • Oct 2019
                        • 324
                        You have a bit a strange problem so I'm going suggest something, not sure if it will work for you
                        How's your transfer unit?
                        Have you stripped cleaned and replaced all the necessary parts in there ?
                        Check to make sure your belts, blades and rollers in there are clean. If you say the problem is coming up once every 500k or so then it could something that's damaging your drum surface slowly. Something like the transfer.
                        • djs9164
                          • Mar 2018
                          • 79
                          This is real common. Humidity does a number on these drums. You need to buy a bottle of NU Finish car polish and buff the drum surface.It will be perfect after that.
                          • Codex
                            • May 2008
                            • 704
                            The machines are in Sicily.... We have this problem not only in winter..... Humidity is a problem, but i think this here is a different problem. But i'll try your suggestion
                            • djs9164
                              • Mar 2018
                              • 79
                              I see this in my schools all the time. The drums seem to pick up moisture. Make sure you use NU Finish, it is a polish NOT a wax. Good luck.
