FTP not working
  • JayPaul
    • Oct 2012
    • 305
    Re: FTP not working
    Doesn't that just show you the full path if it were in SMB format? FTP doesn't seem to have the normal \\DesktopPC\Folder1\Scans
    • menosmola
      • Apr 2014
      • 95
      Re: FTP not working
      You must open port 21 and allow "Program files (x86)\filezilla server\filezilla server.exe" on firewalls....
      On the copier address list, if you only have one address, one folder to scan, use / symbol as path
      • sharpmind
        • Sep 2009
        • 478
        Re: FTP not working
        Originally posted by Oze
        We usually just run the Filezilla server on the customer pc...we don't bother with the client.
        Normally, I am using static IP address in SMTP server when using Filezilla server. Is it possible to use the computer name instead of IP address in SMPT server? Can you guide me on how to configure the setup using computer name?
        • BaconSteve
          • Apr 2019
          • 140
          #19
          Re: FTP not working
          • JayPaul
            • Oct 2012
            • 305
            #20
            Re: FTP not working
            I just need to know how you go further than 1 subfolder, what the path would be?
            Server: 192.168.1.200
            Path: Docs/user1 or Docs\user1 or something else. Because these don't work. Or would it be...
            Server: 192.168.1.200/Docs
            Path:user1 ??
            EDIT - Just figured it out on IIS so that bit is done
              • 37490
              #21
              Re: FTP not working
              Path:user1 ??
              That all depends on what is configures as th e root directory for the FTP server. Read the documentation for the FTP server.
              • menosmola
                • Apr 2014
                • 95
                #22
                Re: FTP not working
                Path:user1 ??
                You must set "aliases" on flilezilla folders config
                In that case, to acces folder from a browser the path is ftp://127.0.0.1/ for the first folder (home folder), ftp://127.0.0.1/1 for the second folder, and ftp://127.0.0.1/2 for the third folder. all folder are individuals, but you also can create a main folder and put other folders inside.
                On the address list of your multifunction, you must set server name "ip of the pc", and path "/" for home folder, "1" for second folder and "2" for third folder.
                • Alexon
                  • Jun 2020
                  • 11
                  #23
                  Re: FTP not working
                  Good day for all of you,
                  I have the same question regarding syntax to fill out filed through Ricoh screen or web app.
                  I was up the IIS FTP.
                  I have an folder FTP on the PC/SERVER with name WORK-STATION
                  My ISS site is FTPScanner
                  When I go to sharing of FTP folder, Network Path is \\Work-station\ftp
                  Location of folder is C:
                  Folder has rights of registered user in IIS and administrator too.
                  Please give your advice.
                    • 37490
                    #24
                    Re: FTP not working
                    Create a new thread.
