Force ricoh mpc 4000 to run without color pcus
  • vga_man
    • 78
    [Electrical] Force ricoh mpc 4000 to run without color pcus
    Hello everybody!
    I have one question if you can advise me and share your knowledge.
    Can i force ricoh color to run with ignoring missed pcu unit?
  • GIUBOSS
    • 1436
    Re: Force ricoh mpc 4000 to run without color pcus
    Like all color laser printers, the mpc4000 performs a color calibration at startup, without the PCU units in color or in black and white it will remain locked. They are basic knowledge.
    • dalewb74
      • Feb 2018
      • 1157
      well if the pcu's are missing then NO. it's gonna continue to throw a code saying the pcu isn't installed.
        • 37533
        If all you want to do is run the machine in B/W only, turn on user code authentication and require it for color copying and printing only.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
            • 37533
            Actually it was fairly easy with the Print Driver Editor. Ricoh discontinued it and replaced (?) it with the Printer Driver Packager which is far more complicates if all you want is the function of the PDE. However the PDE is available from Softpedia should you wish to use it. It only works with the PCL6 drivers and must be used before installing the driver.
            Universal drivers are intended for setting up printer pools with different model MFPs. Pooled printers require that all printers in the pool use the same driver.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              PDE and PDP are certainly what I was referring to.
              I’ve used both with good success.
              I really like the packager, but you’re right...it’s a ton of effort for such a simple task. Not to mention it has to be installed, and is something like a 300MB download from what I remember.
              PDP is definitely NOT for the timid.
