MPC307 scanner skew . .
  • GeorgeBest
    • Jul 2009
    • 526
    HI,
    New machine with a skewing scan, both using the glass as well using the ADF (?!)
    This scanner is fixed I think, can't see an adjustment on scanner rail or other . . .
    Or is there an adjustment available for the scanner or ADF.
    Not that many MPC307's in the field
    Thanks in advance.
    gr George
    • 37553
    Re: MPC307 scanner skew . .
    When you print a counter sheet is it skewed?
    • GeorgeBest
      • Jul 2009
      • 526
      no . . . but copying the counter sheet on the glass or ADF it skewes
        ok so, you have now isolated not to be the print engine.
        from glass and feeder indicates it's not feeder related either.
        now comes the fun part.
        you'll have to remove at the very least, the glass(s) and bezel plastic
        • GeorgeBest
          • Jul 2009
          • 526
          Ok, so I did . . .
          but what can I adjust at the scanner. for so far I can see not much . . .
            Ok, so I did . . .
            the CCD has to move ( either on track or auto scan right?)
            not knowing this model.. admitted ...
            but if it has tracks/gears/belt/cables something is not aligned.
            does the SM have any tools listed that would be a a "jig" for scanner?
            do you have PM for scanner section?
            I would review those sections.. (sorry didn't see any real mention of manual review)
              • 37553
              You say that it is a new machine. Did the skew problem appear upon initial testing in your office or after delivering it to your customer? If during initial testing it is an out of box failure and Ricoh should replace the machine. Otherwise, the scanner frame has been warped during transport, possibly due to placing a tie down strap over the left front corner of the feeder.
              • sandmanmac
                • 3983
                My thoughts exactly!
                • copier tech
                  • 8188
                  HI,
                  Thanks in advance.
                  gr George
                  How much is the skew out by?
                  "New machine?" pass if back to Ricoh under warranty sounds like the scanner was knocked/damaged during transit.
                  • skinnyb
                    • Jul 2008
                    • 291
                    Agreed. If any pressure is put on the left front of the scanner where it is unsupported by the machine below, it can get tweaked. Have seen it happen on the larger machines too. I have removed the scan glass and "tweaked" them back up before back in the day. The little desktops, not as much room to move... That's why our delivery crews drop off these machines still in the box with the Styrofoam support leg still under the scanner for support.
                    Sent from my LM-V405 using Tapatalk
                    • GeorgeBest
                      • Jul 2009
                      • 526
                      Not much, customer complains about it though.
                      0.5mm . . . .
