MPC8002 finisher curling paper
  • digicor
    • Jul 2008
    • 1153
    I have this MPC8002 that the paper hits the finisher and the paper is slightly curled, and it seems to get stuck and not drop properly, then it jams all to hell, ive lowered the fuser temp to 85 from 90, dont want to go to low, and ive waxed the outside of the fin where the paper meets the body of the fin as it stacks, its still doing it after 300 copies its curls up and jams, it didnt do this before when the machine was new its been running about two years, i have new foam gathering rollers, could this be the tray not adjusting up or down when its supposed to ?
    any help would be very much appreciated
  • copier tech
    • 8144
    Re: MPC8002 finisher curling paper
    Paper curl is usually caused by poor quality paper or paper with a high moisture content.
    • digicor
      • Jul 2008
      • 1153
      heres a pic of whats happening, ive lowered the fuser to 80 and the curl is no existant but this occurs intermittently ( see photo)
      so this is probably the real problem
      it looks like a timing issue?
      one piece gets stuck on top of the gathering ropllers and then its just a matter of time before it all gets all trolled up on itself
        • 37483
        Looks like it might be time to replace the gathering rollers.
        • digicor
          • Jul 2008
          • 1153
          they were just done recently
          but ill re do them, this is a new problem the machine has been running for for three years, i have not seen gathering rollers cause this in the lifespan ive had the client
            • 37483
            The other possibility is that the gathering assembly is sticking in the extended position.
            • digicor
              • Jul 2008
              • 1153
              how does one go about lubing them or un sticking them? without the complete dismantle of the fin,im not a fan of blasting into the dark with WD40... LOL
              oh and theres a mail bin stacker on top
