Hi all,
I have this intermittent error during a print run after around 40 pages machine will display 'functional error' with a button to restart.
After the machine restarts it shows "magenta toner not set" simply removing & reinserting the m toner clears the error for around another 40 prints.
In the SC history it logs SC681-012
I've replaced the magenta toner twice but the issue still occurs.
To clarify the machine is not seeing the magenta toner as set, not that the toner is empty magenta print quality is fine.
Any of you guys come across this before?
