03 Models SP Mode access changed from default
  • kwehner
    • Mar 2009
    • 47
    I now have 2 machines that we bought from wholesalers that the previous dealer has changed the SP Mode access code, which makes it impossible for me to enter SP Mode. Does anyone know how to reset the SP Mode back to default? I have looked in the manual and searched copytech and the only answer seems to be replacing NVRAM. If you have info and don't want to post it please PM me.
  • zed255
    How'd ya manage that?
    • 1024
    Re: 03 Models SP Mode access changed from default
    When it was originally announced that the SP mode access was changing it was mentioned that a reset procedure would be released but it appears Ricoh has decided to not make that information available.
    I have not had this happen to me but have you looked to see if the setting is accessible via Factory SP? Have you tried any painfully obvious combinations like 107107?
    • Hadster
      • Aug 2011
      • 264
      Enter Factory mode = 5846-46 to clear
      Sent from my LG-US998 using Tapatalk
      • zed255
        • 1024
        Hadster, I know that SP for clearing administrator and supervisor passwords but have you verified it also resets SP mode access?
        I have not seen confirmation of that. Great if it does.
        • sandmanmac
          • 3981
          Hey Jason, I've verified that it does not reset the SP Code.
          I've been wondering myself what the procedure is, figuring that it will eventually happen to me
          • Hadster
            • Aug 2011
            • 264
            I have not. Just a suggestion.
            • DRichard
              • May 2008
              • 482
              Check in User Tools and see if Service Mode Access has been switched off...
              "Enjoy every sandwich."
              -- Warren Zevon
              • zed255
                • 1024
                Good suggestion. I almost forgot about that. You might have to run SP5-846-46 from Factory SP if this is on as I believe admin access must be on to make the setting for SP restriction. Anyone savvy enough to be restricting SP access via user tools likely has User Tools set up with a password too.
                • kwehner
                  • Mar 2009
                  • 47
                  Service mode lock is off and 5846-046 does not reset it. It does not show up in SP 5990-006 non-default settings or when you print a full SMC. 5801 does not work either.
                  • zed255
                    • 1024
                    D'oh! Went to SP5-801-1 already, from Factory SP I have to assume. I wish people would go to that way less often than they seem to. I can count on the fingers of one hand, with digits left over, the number of times a full reset (which isn't very full as you can see) has done ANYTHING positive. Hopefully you backed up the NVRAM to be able to restore it, otherwise you may have issues with image quality and process related items.
                    • Coptech
                      worker drone
                      • 460
                      Go into factory mode and look at 5081. If I remember correctly, that is where the new code is set.
                      • kwehner
                        • Mar 2009
                        • 47
                        5081 is not in factory mode.
                        • kwehner
                          • Mar 2009
                          • 47
                          ZED255 you are a genius!
                          107107 may be painfully obvious to you but I did not think of that. I tried a hundred other codes, serial number, model number, year made, etc. both forward and backward. Fortunately, it worked on the one in the shop, the other is in the field already, so I will try that when I get a chance.
                          That still doesn't solve the real problem of resetting it if you can't guess it.
                          • zed255
                            • 1024
                            Once you are in regular SP you should be able to change it back to the default one. People are lazy so they use 107107 because it is similar to SP of old.
                              • 37488
                              And 5081 is the ServiceSP Entery Code Setting. I am wondering if it can be changed through telnet?
