I have an Mp 305 that is down with a SC673-10, all word in the error message are displayed in Japanese. Words outside of the error message, like "Please wait" are in English. I have tried new HDD, Controller PCB, Smart Operation Panel. Also reflashed the firmware. Can not get into service mode. I'm not sure where to go with it next, Ideas?
MP 305 SC673-10
Re: MP 305 SC673-10
You could try this:
Check If SP5748-201 is set to "0" (Not connect), change the value to "1" (Connect).
Seems that the control panel is sending a signal to the controller and the controller is not responding.
Sent from my SM-G950F using TapatalkPress the GREEN button!!Comment
Re: MP 305 SC673-10
I'd like to try that, but can not get into service mode, probably because the Op panel is not talking to the Controller.Comment
Re: MP 305 SC673-10
I noticed that the USB cables that use ricoh in his machines to connect sop to controller, are really suck, they seem the cheapest of those of Chinese battery chargers for smartphones, (with respect for the Chinese people who here are always nice and educated!)."I'll be back"Comment
Re: MP 305 SC673-10
Fixed, I ended up replacing the navram on the controller PCB. Thanks for all the ideas. This one took me many tries of parts out of a donor machine until I finally tried the navram. A rare problem for sure, I don't think I've ever had to replace navram before.Comment
Re: MP 305 SC673-10
Glad you got it fixed.
Just to relate my own issues with a MPC 406 that I was fighting with a SC 673-10, the SM is very misleading and so was the hotline. SOP didn't fix it and neither did the harness between the BCU and the panel. I could navigate all I wanted as long as I stayed in the panel. (Like go to panel user tools for example), but nothing for the machine would pop up. The only icons that are on the screen are for the user tools. Eventually the machine would code a SC673-10.
I was talking to another tech about this and he mentioned disconnect the HDD and try it. Well the sucker came up. Put all the original parts back on with the new HDD and it came up. The hotline did mention the BCU NVRAM as a potential culprit. My take on the hotline is a lot of times they are sort of worse help than no help and I have had them suggest replacing the NVRAM way too often. It is extremely rare that NVRAM is actually bad on a machine although it was the case on the OP's machine in this thread.
At any rate, keep in mind if you run into SC 673-10 issues, the HDD can be an issue even if it isn't mentioned in any of the troubleshooting steps of the manual.Comment
