MP2851 with random black dots
  • copyaction
    • Oct 2007
    • 991
    Looks like the typical worn out PCU symptom but not in this case.
    I have already replaced with brand new genuine type 1027 PCU (twice in case the first was defective)
    Replaced transfer roller.
    Cleaned all drum contacts and drum cavity, which was very clean to begin with, unlike some of this model you see out there.
    Only uses genuine Ricoh toner supplied by me.
    Not sure where to go next on this one.
  • zed255
    How'd ya manage that?
    • 1024
    Re: MP2851 with random black dots
    Fuser issue, like the pressure lever is lowered for envelope mode.
    • anothertech
      • 1769
      1+ on the fuser, the teflon roller coating gets worn off.
      • copyaction
        • Oct 2007
        • 991
        Sorry guys I forgot to mention I stopped it before the fuser and the dots were already there.
        I also checked the upper roller and it has no buildup on it.
        So it is happening before it gets to the fuser.
          • 37489
          Bad cleaning blade or toner build up in the toner recycler due to a build up of paper lint blocking the opening at the end of the recycler.
          • davel
            • Oct 2011
            • 1104
            OP said new PCDU.
            • luca72
              • Oct 2017
              • 1778
              this usually happens when the pcdu is replaced without replacing the transfer roller, when the replaced pcdu becomes old it enhances the problem of the transfer roller.
              you say you have replaced them, I don't know how many prints they have done, but on these types of machines it is necessary to replace pcdu + transfer roller together.
              "I'll be back"
              • copyaction
                • Oct 2007
                • 991
                Yes brand new entire pcdu (type 1027) and brand new transfer roller both installed yesterday.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Which toner do you use?
                  • CopyBats
                    • Aug 2011
                    • 146
                    If it's not this, take a used working drum in good condition to see if you can recreate the problem. Couple of 1027 have been bad in the box
                    If it works, don't touch it.
                    • copyaction
                      • Oct 2007
                      • 991
                      Only genuine Ricoh 2120d and they get it from me.
                      • copyaction
                        • Oct 2007
                        • 991
                        I actually had a used 1027 drum with me that just had a thin line on it.
                        I swapped it in to test and it had the thin line plus all the dots.
                          • 37489
                          Originally posted by davel
                          OP said new PCDU.
                          There is no longer any "New" type 1027 PCU from Ricoh. Ricoh went to selling rebuilt Type 1027 a couple of years to meet the demand created by lazy techs using them instead of rebuilding those for later models.
                          • copyaction
                            • Oct 2007
                            • 991
                            That is a good point which is why I tried a second unit just in case.
                            • wcanonw
                              • Aug 2014
                              • 404
                              hello, the counter page is printed in a4 or a4-R (LTR or Ltr - R), did the unit you replace contain a new developer?
