MP2851 with random black dots
  • mikadonovan
    • May 2008
    • 2931
    Re: MP2851 with random black dots
    After looking at the counter sheet solid triangle, I see that there are white spots on it indicating to me contaminated developer.
    NEVER ASSUME ANYTHING
    • copyaction
      • Oct 2007
      • 985
      Originally posted by wcanonw
      hello, the counter page is printed in a4 or a4-R (LTR or Ltr - R), did the unit you replace contain a new developer?
      LTR and yes it had new developer and as I mentioned I tried another used unit with only a line but no dots, and it too had dots when placed in this machine.
      • copyaction
        • Oct 2007
        • 985
        • luca72
          • Oct 2017
          • 1710
          #19
          There is no longer any "New" type 1027 PCU from Ricoh. Ricoh went to selling rebuilt Type 1027 a couple of years to meet the demand created by lazy techs using them instead of rebuilding those for later models.
          long ago, I also heard this story, it seems to have come from France .. for now those few that we are replacing on machines with type1027 work very well ...
          • luca72
            • Oct 2017
            • 1710
            #20
            Originally posted by copyaction
            I actually had a used 1027 drum with me that just had a thin line on it.
            I swapped it in to test and it had the thin line plus all the dots.
            [COLOR=rgba(0, 0, 0, 0.54)]
            [/COLOR]
            [/COLOR]
            ..and then friend the only solution and disassemble it, it's so easy and fast, and replace the components one at a time, and try, even the frames! separately, even the black plastic part that electrically connects the charge roller, once a colleague has unsoldered the ball that is inside and I don't remember exactly, but it was a strange defect
            • luca72
              • Oct 2017
              • 1710
              #21
              [/COLOR]
              [/COLOR]
              personally this defect has always seemed to me more an electrical disturbance than something to do with toner
              • copyaction
                • Oct 2007
                • 985
                #22
                Well I feel dumb now. It was actually happening before the drum. The two foam rollers just passed the paper trays had completely deteriorated.
                • luca72
                  • Oct 2017
                  • 1710
                  #23
                  If I understand correctly, do you say that the powdered foam has joined the drum / charge roller? Looking at the pdf I don't see a repeat from diameter, it seems a little 280k print to have such a problem, but where is it installed on the beach?
                  • copyaction
                    • Oct 2007
                    • 985
                    #24
                    No it was the two foam transport rollers in the paper path.
                    Toner was sticking to the deteriorated foam and being transferred to the paper prior to it reaching the drum
                    • luca72
                      • Oct 2017
                      • 1710
                      #25
                      Ahh, now I understand, interesting!
                      have you tried cleaning / replacing that roller and the problem is gone?
                      But was the machine very dirty in general?
                      Usually that problem is either the pcdu or the transfer roller.
                      I must point out that I am a cleaning maniac.
                      Since this lengthens the interventions a little, my boss often tells me on the phone: "ohh, but are you still alive? But what are you making love with machines?"
