MPC5502a start up slow and no VMcard in slot 2
  • Hadster
    • Aug 2011
    • 264
    Java is installed and I would like to uninstall but the machine came in without a VMcard anywhere. Can it be uninstalled without it? I am assuming this is why the copier is taking so long to do anything.
    Tried Memory clear NOT 1 and 2 of course.
    New HDD and reformatted.
    It has one other problem... I can't allocate functions for the hard keys. They simply do not show up.
  • anothertech
    • 1769
    Re: MPC5502a start up slow and no VMcard in slot 2
    Try changing SP5730 from 1 to 0 to disable java, then reboot.
    • Hadster
      • Aug 2011
      • 264
      ooops! forgot to mention I did that as well.
      • copier tech
        • 8144
        If you have disabled JAVA with SP5730 you can uninstall it from additional functions.
        However this is unlikely why the machine is taking so long to boot. How long are we talking?
        • skinnyb
          • Jul 2008
          • 291
          The 5502 Java is on an SD card not embedded like the 03 models and newer. If there is no VM card but there is a card in one of the slots, chances are someone merged (tried) Java to that card, in most cases when this happens its the PS card. If there is no card in either slot there is a larger issue of some kind.
          Sent from my LM-V405 using Tapatalk
          • Hadster
            • Aug 2011
            • 264
            I ended up using a spare controller out of a junker. I needed to install this machine in the morning! I now can see to options to load the function keys and machine is much faster to enter user tools, sp mode, etc... Thanks everyone!
            Sent from my LG-US998 using Tapatalk
