Replace Toner will not clear Lanier LD425c
  • zed255
    How'd ya manage that?
    • 1024
    Re: Replace Toner will not clear Lanier LD425c
    The newer style (D029) will work in the older machines. They new ones have a smaller clutch than the old ones, but mount points, harness and hose are the same. If you can't get the original style then get one for a Ricoh MP Cxx01 or MP Cxx02 series and you should be set. And don't be lazy, the new pump includes the hose for a reason, install it.
    Don't waste your time and effort trying to resurrect the old one. Some say they have but guaranteed it will fail again. Just replace it.
    • fshead
      • 2376
      I dont think you can use a mpc330 pump on the mpc2500..
      I tried using a mpc2500 pump on my mpc3300 and they did not fit...
      I know mpc3300/mpc2800,mpc3501,mpc3502 all cross over..and the print models too spc830 etc..
      • fshead
        • 2376
        Originally posted by GIUBOSS
        you can also put a pump of another color better if new, before I revised the old ones and changed the rubber inside but it was time wasted and then lasted less, not convenient
        i just swap a color in just to get them up "temp" for b/w,maybe do a forced cyan feed b4 pulling a cyan pump....
