Re: Replace Toner will not clear Lanier LD425c
The newer style (D029) will work in the older machines. They new ones have a smaller clutch than the old ones, but mount points, harness and hose are the same. If you can't get the original style then get one for a Ricoh MP Cxx01 or MP Cxx02 series and you should be set. And don't be lazy, the new pump includes the hose for a reason, install it.
Don't waste your time and effort trying to resurrect the old one. Some say they have but guaranteed it will fail again. Just replace it.
