MP 4054, Fusing problem, Print quality
  • Like1mS
    • Jun 2018
    • 23
    [Misc] MP 4054, Fusing problem, Print quality
    Hello,
    I didnt find any one mentioning it on forums here. So i post a thread.
    We have MP 4054 machine. The problem is that toner doesnt always fuse to paper.
    And the image repeats itself. So far we have:
    • Raised fusing temperatures.
    • Increased fusing idling time.
    • Replaced Fusing sleeve ( D895-4034 ).
    Machine still doesnt always fuse toner to paper. Sometimes prints come out fine.
    Pictures attached.
    Any suggestions? I appreciate any answers. Thanks a lot.
  • Zeldaman
    • Mar 2011
    • 946
    Re: MP 4054, Fusing problem, Print quality
    Hi there!
    How old is: fuser, drum, developer ??????
    If the counter on the sheet is correct, is it the 1. Fuser ?
    We need more info, cause our cristall-balls hanging on the christmastrees.
    Greetings...
    • Like1mS
      • Jun 2018
      • 23
      Originally posted by Zeldaman
      Hi there!
      Greetings...
      • Fuser - 291675/320000
      • Fusing Belt (Sleeve) - 328/320000
      • Drum - 291675/160000 , Drum was replaced, counter was not reset.
      • Developer - 291675/160000, not sure about developer, can developer cause this ?
      Never seen before. I dont think developer has anything to do with the problem.
      Toner simply doesnt fuse to paper from time to time.
      Also before replacing the sleeve it was 2/10 pages that came out not fused right.
      After replacing the sleeve unit its 8/10 pages that dont fuse correctly.
      Thank you for your answer.
      • GIUBOSS
        • 1437
        it could be paper, or thermistors. Install a heater over the paper tray
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          If not replacing the complete fuser, allways change sleeve, pressroller + bushings & thermistors as a bundle. Otherwise such problems will occur.
          Greetings...
          • skinnyb
            • Jul 2008
            • 291
            Hi there!
            Greetings...
            I agree. I never replace just the sleeve, the pressure roller is a consumable too. They get weak and lose their elasticity. Always replace the sleeve, bearings and pressure roller as a set. I usually just clean thermistors, if they are in rough shape I replace those too.
            Sent from my LM-V405 using Tapatalk
            • Dan G
              • Nov 2014
              • 56
              I would consider checking whether pressure is even on both sides of fuser???
              • KonMan
                • Mar 2010
                • 15
                Ii had this exact system on a new fuser unit from Ricoh. One of the lower bearings had "popped" out of place.
                Sent from my SM-T378V using Tapatalk
                • Like1mS
                  • Jun 2018
                  • 23
                  We replaced the new fusing lamp with the old one, as they were different.
                  Keeping the new sleeve and so far everything works.
                  D895-4034 (Sleeve Unit) is for a different machine, looks the same, fits, but the lamp is different.
                  Thank you all for help. And a happy holiday season.
                  • luca72
                    • Oct 2017
                    • 1792
                    Originally posted by Like1mS
                    Hello,
                    Pictures attached.
                    [ATTACH=CONFIG]44344[/ATTACH][ATTACH=CONFIG]44345[/ATTACH]
                    check via sp output check the release mechanism and pressure roller pressure, you have replaced the sleeve, you would inadvertently mount something wrong, remove the fuser and operate the mechanism with your fingers to see if it really works
                    "I'll be back"
                    • mikadonovan
                      • May 2008
                      • 2931
                      Are you using an aftermarket toner?
                      NEVER ASSUME ANYTHING
                      • Dan G
                        • Nov 2014
                        • 56
                        MP2554 is different than fuser in the faster units
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          Give this a shot.
