Ricoh mpc5503 mystery lines
  • msmy
    • May 2010
    • 123
    hi there,
    I need some advise from expert here. recently i faced with mystery black lines ONLY WHEN PRINT/COPY IN FULL COLOR and will be ok when print/copy in black/white. The problem will come after 15 or 20 copies or A4.
    what has been done;
    1. new black drum and drum blade
    2. new pcr and blade
    thank you guys.
  • davel
    • Oct 2011
    • 1104
    Re: Ricoh mpc5503 mystery lines
    The usual questions, PM counters on all parts? what is this PCR blade you mention? how is the lube bar? if it does not happen on B/W printing the problem is not in K PCDU.
    Merry Christmas.
    • anothertech
      • 1771
      I'm thinking ITB cleaning unit, is it due for replacement?
      • mikadonovan
        • May 2008
        • 2931
        Print a blank sheet with each color programmed as a background to determine which pcu is causing the issue.
        NEVER ASSUME ANYTHING
