RICOH MP 7503 J003
  • bojans
    • 1313
    RICOH MP 7503 J003
    Hi,
    I got this unit with 1M on counter.
    It jams on every cassette on the feed.
    I dont have other working unit to change paper feed, have to wait long time to new one to arrive.
    regards
  • GIUBOSS
    • 1407
    Re: RICOH MP 7503 J003
    you have already tried to clean the paper feed rollers
    • bojans
      • 1313
      Yes, I did.
      Tried with working one from previous model.
      • davel
        • Oct 2011
        • 1099
        J003 is tray 1 jam, what jam code do you get from other trays?
        • bojans
          • 1313
          J004
          J005
          • GIUBOSS
            • 1407
            Originally posted by bojans
            Yes, I did.
            if the paper feeds of all the paper trays are worn, try the ones in the bypass.
            • bojans
              • 1313
              Did that, too.
              • GIUBOSS
                • 1407
                have you done sp tests of paper passage sensors and motors?
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  If you pull the feed stations out, is there developer on the back of them? It could be the dev unit is leaking and has contaminated the one-ways in the feed units. I'd be surprised if it was that though with only a million on the clock.
                  Hit it.
                  • bojans
                    • 1313
                    I know all that problems, but there is no leaking of developer. All the gears in great condition.
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      How far does the paper make it out of the tray, if at all? The paper feed board could have died.
                      Hit it.
                      • bojans
                        • 1313
                        It makes couple copies sometimes. Tray 2 has made 3K first day we run it. Now non of the cassettes not feeding. It also tears paper, I suspected to Sep pad and tried to adjust tension. I
                        • GIUBOSS
                          • 1407
                          you wrote that all the trays have the same problem, I don't think the torque limiters are all defective, you tried to exchange them.
                            • 37422
                            I wonder why you don't stock any paper feed rollers. Unless you are using the black 300K rollers, no amount of cleaning will help. With the 1M rollers once the surface of the feed roller becomes shiny and slick it must be replaced. That frequently happens at around 600K to 800K.
                            • MIKON
                              • Jul 2015
                              • 186
                              I never let the separation roller go past 300k.
