RICOH MP 7503 J003
  • bojans
    • 1313
    #16
    Re: RICOH MP 7503 J003
    Waiting for new rollers. Thanks for all help.
      • 37562
      #17
      Originally posted by MIKON
      I never let the separation roller go past 300k.
      The problem is not the separation roller unless you are getting more that one sheet at a time.
      • MIKON
        • Jul 2015
        • 188
        #18
        When the seperation roller is bad it will fold the paper and jam!
          • 37562
          #19
          When the feed roller is slick the separation roller will turn in reverse direction bending the center of the paper and causing a jam. When the separation roller is bad it will feed more than one sheet of paper. When the torque limiter is bad it will pick multiple sheets of paper, often as many as ten or more.
          • MIKON
            • Jul 2015
            • 188
            #20
            Apparently the laws of physics are different on the west coast.
              • 37562
              #21
              You need to study the theory behind the three roller pickup-feed-reverse paper feeding system.
              • MIKON
                • Jul 2015
                • 188
                #22
                That's the difference between me and you I only post on here what I see.
                I work exclusively on d052 d052 d131 with a monthly copy. Volume o 4.5mil...
                  • 37562
                  #23
                  Then you should know how their feed system works. Of course Ricoh is partially at fault for no longer putting a Detailed Descriptions section in their service manuals
                    • 37562
                    #24
                    FYI I have worked on all the Martini machines from the A283 on up to the 03s. I have also worked production models doing 3M to 5M a year.
                    • bojans
                      • 1313
                      #25
                      Separation rollers was causing problems. After installing new one all feeds are working.
                      I still don't understand why it wasn't working with rollers from working MP6502 ???
                      also, bypass rollers not the same as in paper feed from trays.
                      thank you all for help.
                        • 37562
                        #26
                        The one way bearing in the feed roller turns the opposite way in the bypass and the LCT. If you replaced only the separation roller, the problem will return quickly.
