RICOH MPCXX04/04ex squeaking
  • enricos
    • Mar 2019
    • 19
    [Misc] RICOH MPCXX04/04ex squeaking
    Hi everyone,
    I noticed that various multifunctions MPC 04 and 04ex series, after some months of work produces a high and annoying squeak from the right side (duplex). I've tried to switch the entire duplex with another one (used), transfer unit and the itb unit. Does anyone have any ideas?
    Thank you
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: RICOH MPCXX04/04ex squeaking
    Could be exit assy pinch rollers
    Regards Mark
    • copier tech
      • 8133
      Originally posted by enricos
      Hi everyone,
      Thank you
      Have you run output checks to ensure it is the duplex?
      Usually squeaks come from the PCU when they are near/past PM life.
      • semi
        • Sep 2008
        • 193
        Black PCU,run in output mode
        • JDYAL
          • Sep 2008
          • 187
          Exit assembly.
          • Imprestik
            • Aug 2012
            • 297
            As mentioned above, it's either your K PCDU or the ITB unit.
            Also at mentioned above run the output check on the K drum dive/transfer motor
            • luca72
              • Oct 2017
              • 1759
              Hi everyone,
              Thank you
              the only way to solve a strange noise its run output check one by one, at various speed
              "I'll be back"
              • enricos
                • Mar 2019
                • 19
                Solved changing the PCU black. Thank you all
