MP 201 SC 670/firmware update
  • thurmmy
    • Aug 2016
    • 102
    OK, so I attempted to do a firmware update on a MP 201, got a SC 670. I know what happened as per previous threads. I have the copier up and running with another BICU and presently have another controller box installed. My question is, is the old controller box shot with the wrong engine firmware? Should/can I put original NVRAM into the controller that is now in to get my s/n etc. back? Hope I'm making sense. I just don't want to destroy another BICU. Thank you in advance.
  • GIUBOSS
    • 1437
    Re: MP 201 SC 670/firmware update
    why the firmware update? 1) it may happen that the firmware is not loaded correctly or for the damaged file or for the incorrect or damaged sd card. 2) sc670 BICU defective but it can also be there
    Defective controller board. The incorrect firmware update sends the NVRAM to a block and must be replaced or reset. Probably the BICU is not damaged but inhibited by the NVRAM.
    • Polarbear
      • Feb 2012
      • 1070
      There was a time, while the MP201 was being sold, when there was a tsunami in one of the industrial areas in Japan, that totally disabled one of the factories where the main boards for the 201 were being made.
      Ricoh switched to a different supplier and with this one of the main chips on the board also changed (therefore the SC670 if the wrong firmware is loaded on the wrong board).
      To my knowledge there is no recovery for this other than to replace the board in question.
      Press the GREEN button!!
      • thurmmy
        • Aug 2016
        • 102
        That is exactly what happened. So anyone who is doing fwu. make sure you are using the correct engine firmware.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Where did you get the original firmware from?
          Coz THIS is the message that we have on the Official My Ricoh site :
            • 37556
            That's because they need to check which controller board you have.
            • copier tech
              • 8192
              On this old discontinued mono model there is no benefit in updating the firmware.
