Pro8110 SC401-01, 402-51 and 410-01
  • mrwho
    Major Asshole!
    • 4299
    [Error Code] Pro8110 SC401-01, 402-51 and 410-01
    Mascan42
    Ibid
  • GIUBOSS
    • 1410
    Re: Pro8110 SC401-01, 402-51 and 410-01
    condition of the drum ?. You cleaned all around the drum led sensors
    • mrwho
      Major Asshole!
      • 4299
      The drum has around 1.6m pages (around double of the machine TC, since most of it is A3/DLT or above) - since the drum is rated to 2.5M, I didn't consider it.
      The only sensors I know around the drum are the potential sensor and he temperature/humidity sensor - Unless you're refering to the quenching lamp?
      Mascan42
      Ibid
        • 37447
        • anothertech
          • 1766
          • butcher
            • 48
            Have all the filters been replaced ? especially the Ozone ones ?
            • mrwho
              Major Asshole!
              • 4299
              After draining the old developer and before installing the new developer did you clean the surface of the development roller IAW bulletin D179/D180/D181 – 038 REISSUE? The cleaning tapes needed are packaged with the developer D1809640. If you used the old developer part number D1799640 or after market developer you must order the cleaning tapes separately D1793414.
              SC401 can also be caused by NOx (nitrogen oxides) build up when the machine set overnight. See bulletin D179/D180/D181 – 011 REISSUE for details and solution.
              No, there were no cleaning tapes with the developer I replaced - I found out that bulleting after replacing the developer (when the problem came up). I then took a good look at the mag rollers and cleaned them the old fashioned way - and didn't notice much difference. Granted that could be because the cleaning method wasn't ideal, but the rollers looked good to me, specially when compared to other machines in the field that don't show these symptoms.
              To be honest, I didn't even think about it again until I read your post - I'll order the tapes and, if the symptoms come up again (after today's machine cleaning), then I'll put them to good use.
              Originally posted by anothertech
              Try this, it came from tech bulletin D179/D180/D181 – 061
              SP 3201-002: [TnrDensity] Lower TC 4.5 to 3.0 [wt%]
              SP 3231-001: [Vtref Limits :Set] Upper:K 3.22 to 3.62 [V]
              SP 3622-061: [Dev Pot :Set] LowerLimit:K 200 to 100 [-V]
              I'm at home right now, but I'm almost sure those SPs were amongst the ones I changed - the last one I'm sure of it, at least. I'll double check when I get back at a future call.
              No, at least not by me - it's possible that a colleague did replace them. But that's a good point to check that haven't ocurred to me.
              Thank you all again for your suggestions. I'll keep you posted!
              Cheers!
              Mascan42
              Ibid
              • anothertech
                • 1766
                If you order the D1809640 Developer, the tape comes with the Developer. I have used the tape 3 or 4 times, to be honest I have never seen the tape make any difference. I don't even bother with it any more.
                I'd stretch the limits of SP3231-001 and SP3622-061 a little more than the tech pub.
                I didn't see if you cleaned the doctor blade or not, but even if you did, I'd clean it again.
                • mrwho
                  Major Asshole!
                  • 4299
                  I'm sorry to revive this old thread of mine, but it came up on another thread and just today I noticed I failed to give a follow up.
                  It's been almost 6 months, so I'm not exactly sure of what the SPs were, but according to the worksheet, I raised the machine's tolerance for the given errors - So I probably followed anothertech's advise. The problem didn't come back ever since.
                  Thank you all!
                  Mascan42
                  Ibid
