Ricoh pro906ex SC990 code
  • jacanape
    • Feb 2019
    • 22
    [Error Code] Ricoh pro906ex SC990 code
    My machine has error code SC990.
    Can anyone help me to fix this?
    Thanks, Jacanape
  • davel
    • Oct 2011
    • 1089
    Re: Ricoh pro906ex SC990 code
    What does you service manual tell you to do?
    • jacanape
      • Feb 2019
      • 22
      See instructions in attachment...
      Procedure 1 : there is no HHD replaced
      Procedure 2 : executed SP5990 004 : blanc page came out... and a new service code appeared : SC 996
      Code SC996 appeared already before SC990,
      as instructed in the manual I replaced the polygon mirror motor but with no result. After that SC 990 appeared.
      After replacing the motor the code changed from SC996 to SC990.
      • totoro
        • 568
        update to latest firmware or reflash if already there
        Totoro
        • jacanape
          • Feb 2019
          • 22
          OK, I'm no pro so can you tell me how to do that?
          • anothertech
            • 1757
            how to do what? Load firmware? Call local pro tech.
              • 37048
              If you do not know how to do that , you should not be trying to work on production printers.
              • butcher
                • 48
                Thanks, Jacanape
                Hi Mate,
                SC990 can mean many things. There's usually a line of data that accompanies it.
                For example if has some like SC900 : ProCon xxx, It could mean there is a problem with Devices process control and may need a PM service done.
                Just a thought
                  • 37048
                  SC990 is a software performance error.
                  A little more history of what happened before the error could be helpful. As an example, if the HDD was replaced but the stamp data was not downloaded to the new HDD you will get this error. Other than that you need to call the Ricoh regional desk. Be sure to have the information as to Function, Line and Value associated with the error code.
                  • jacanape
                    • Feb 2019
                    • 22
                    I called in a technician. He has reinstalled the firmware and replaced the drum.
                    According to him, the LD (B2341895) is defective. (SC240 + SC966).
                    Price: $ 950. Because I don't have the money for that, I have to find another solution.
                    I'm thinking of a second-hand LD.
                    Can anyone help me with this?
