Ricoh MP 7502 light copy and print quality
  • edi1907
    • Dec 2015
    • 15
    I changed drum and developer but I still get light quality when I take print or copy. Anybody help me please?
  • davel
    • Oct 2011
    • 1107
    Re: Ricoh MP 7502 light copy and print quality
    What about the rest of the PM parts? Did you initialise dev correctly and clean everything first, was dev roller clean.
    • eccelobo
      • 113
      Check transfer belt unit
      • morgansterne
        • Oct 2007
        • 83
        • GIUBOSS
          • 1437
          if this were the case, it would not be possible to insert them. They have obligatory pins.
          • GIUBOSS
            • 1437
            suck the whole part around the drum including led lamps, filters, replace the other parts too see the pm counter list (at least those of the drum and transfer section) also clean the scanner section. Total number of pages? There are other posts on this classic problem with similar models.
            • anothertech
              • 1771
              You can get them in there but not seated right, I have done it a few times. Definitely worth a look.
                • 37556
                Do not suck (vacuum) anywhere near the ID sensor as doing so can generate enough static to damage the sensor. You can vacuum most of the drum frame but stay at least 1 inch away from the sensor. Use an artist's brush to remove toner next to the sensor. Clean the face of the sensor itself with a soft cotton cloth moistened with water only, anything else can damage the sensor.
                • edi1907
                  • Dec 2015
                  • 15
                  I changed transfer belt also but how could I make a mistake for this?
                  • fshead
                    • 2376
                    I agree as i have in the past too.
                    would be nice if a little more info is given when seeking help.
                    its like pulling teeth with some posters..........
                    • fshead
                      • 2376
                      I always pull both sensors out,the one on the top of the clam shell, and put them to the side..
                      This way i can vacuum out w/out any issues....
                      • MIKON
                        • Jul 2015
                        • 188
                        I just had a bad toner hopper that caused light copies.after a developer change.They don't usually break but something to check.
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          Have you cleaned laser glass and maybe laser unit
                          Regards Mark
                          • fshead
                            • 2376
                            I think it cloggs over time too and a quick vacuum will remedy..also that plastic piece above dev unit with the 2 mylars that fall off too when toner comes back from drum unit....
                            • Cserv
                              • Jan 2020
                              • 4
                              After ck all the above try to force toner supply and print a test pattern (checkers flag) before and after to see if any change.Plus ck if the toner is oem
