ricoh aficio 3350 no sound during fax initial transmission.
  • johnwayne
    • Sep 2019
    • 23
    when answering the fax line, there is no sound from the aficio. when sending a fax, no dial tones are heard, nor any sound from the connection being made. in user tools/facsimile features, all the volumes are set to '3', and can be heard when pressing 'check'. in the SP menu, all i can find relative to fax sound is the 'test' menu, and each sound is heard during testing. in the facsimile menu, the dialtone can be heard when pressing 'on hook'. i have not found any settings beyond what is shown in the features menu over in the 'web image monitor'. the machine works, and has been 'silent' when faxing since i bought it (second owner). I would like to enable the fax sounds. Hope someone can suggest something i have not tried, and yes i have been through the manual many times. thanks in advance.
    • 37556
    Re: ricoh aficio 3350 no sound during fax initial transmission.
    1. Have you checked that the cord to the wall jack is plugged into the "Line" jack on the 3350 and not the "Phone" jack?
    2. Have you unplugged the cord from the 3350 and plugged it into a single line phone to test the cord and the wall jack for dial tone?
    • johnwayne
      • Sep 2019
      • 23
      yes, walljack to line jack on 3350, phone jack on 3350 to phone.
      yes, there is dialtone from phone, and the 'on hook' has dialtone as previously stated. the machine sends and receives faxes perfectly - just totally silent.
      • davel
        • Oct 2011
        • 1107
        Why would you need to hear that fax noise and why would you need to fax anyway.
        • copier tech
          • 8192
          If as you say the machine send/receives fax fine & you get a dial tone when pressing "on hook" this is normal no one wants to hear the fax transmission noises (except you clearly!)
          • johnwayne
            • Sep 2019
            • 23
            @davel & @copier tech ..
            I thought a forum was a place to ask legitimate questions.
            Thanks for increasing the activity count on my post, that will possibly help it get the attention of someone wanting to actually help someone else.
            Why do I want to hear the fax, or even fax in 2020? Why do you want to waste your own and everyone's else's time with ineffectual responses in a forum? Answer: cause people gonna do what they want to do, lol.
            Next!
            • copier tech
              • 8192
              Next!
              Since you have a terrible attitude to people trying to help read the service manual & find out for yourself which SP mode turns on the transmission sounds......................
              • anothertech
                • 1771
                This poster is asking a valid question about faxing, and he is being treated very poorly, why not just answer the question or leave it alone.
                As to why use a fax in 2020, many hospitals and doctors use fax instead of email because fax is much more secure, it's harder to hack than email. Also many government offices are behind the times and still use fax every day.
                It really does not matter why the customer is still using fax, if they require fax, we provide fax.
                As for hearing the tones, some customer want to hear the tones so they know when it's communicating, again, it does not really matter why they want them on, if they request the tones, we give them tones.
                • copier tech
                  • 8192
                  If he had simply replied & explained this we would have given him the answer he was looking for.
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    • DRichard
                      • May 2008
                      • 482
                      Make sure your fax speaker is plugged in.
                      "Enjoy every sandwich."
                      -- Warren Zevon
                        • 37556
                        If it was not plugged in, he would not be able to hear th e dial tone when he pressed the "On Hook" button.
                        • COPIERMAN
                          • Jun 2009
                          • 559
                          If you are doing memory fax it will not make sound but it you you do immediately transmission will hear it dialing out and everything else if sound is turn on for each mode.
                          • DRichard
                            • May 2008
                            • 482
                            WHAT?! SPEAK UP SONNY!!!
                            -- Warren Zevon
