MPC3002 Can't do a printer automatic colour calibration
  • solorajder
    • Jul 2010
    • 106
    Hi,
    I try to do a printer automatic colour calibration but I don't have a options to choose on screen, only for copier is on screen.
    Also I can't get to Printer SP mode.....when I press Printer SP I get this, others SP works fine.
    The printer is working normally, machine have latest firmware.
    Strange....Any idea?
    I would appreciate any advice.
  • Codex
    • May 2008
    • 705
    Re: MPC3002 Can't do a printer automatic colour calibration
    Try to do a memory clear ONLY for the printer
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
    • COPIERMAN
      • Jun 2009
      • 559
      When you go into user tools look for log in button if it has it must login to use feature. administration authentication some one must had enable some control of features.
      • solorajder
        • Jul 2010
        • 106
        I do the printer memory clear... but it is the same.
        Sent from my G8441 using Tapatalk
        • solorajder
          • Jul 2010
          • 106
          I don't have login button because The Administrator authentication management is off.
          • fshead
            • 2378
            i dont think he knows what you suggest.
            Does printer show up in user tools or via service mode?
            IF he cant answer that i think he is lost and over his head..........
              • 37628
              There are a number of security settings that not only can you not change if you are not logged in, you cannot even see on the screen if Administrator Authentication is OFF. Turn Administrator Authentication ON and log in as Machine Administrator. Change all security settings to the minimum level.
              • GIUBOSS
                • 1437
                • GIUBOSS
                  • 1437
                  Hi,
                  [ATTACH=CONFIG]44778[/ATTACH]
                  [ATTACH=CONFIG]44779[/ATTACH]
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    "setting change" is on the display (see second photograph) when opening the printscreen on your machine.
                    So, your machine is bussy trying to run a change (or something).
                    Is there an extra (scan)program on board of this machine?
                    • Coptech
                      worker drone
                      • 460
                      It will only print test pages from tray one and also only if paper type is normal. Paper set to anything differently, and it will fail to print calibration pages.
                      • mikadonovan
                        • May 2008
                        • 2931
                        Good call, and according to his pics, tray 1 IS empty.
                        NEVER ASSUME ANYTHING
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          RED CARDER RED CARDER KEEP TRYING HARDER....
                          Sorry...couldn't help it....newbie error and he probably won't post up again out of embarrassment
                          • solorajder
                            • Jul 2010
                            • 106
                            Sorry but I'm not a newbei. All of your suggestions was useless because I alleady tried it before I post a question.
                              • 37628
                              With only 83 posts, 4 of them on this thread, in almost 10 years as a member you may not be a newbie but you are definitely not a quality or trusted technician. If you had already tried all the suggestions given in this thread, why did you fail to enumerate them two and a halt months ago in your first post? Of course in that length you have most likely forgotten what you really did.
