MP2555 fusing issue
  • CableGuy
    Impulse Drive Engineer
    • Oct 2008
    • 417
    MP2555 fusing issue
    Hi All, been a while
    I'm having an issue with a MP2555 where the last 1cm of the print (LEF) isn't fusing correctly and then deposits that bit of toner on the second page about an inch in from the lead edge. This issue was happening over a larger area of the page when the original tech attended, so he replaced all the fusing and PDCU parts a week ago.
    All temps look good and not tampered with.
    Thanks in advance
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MP2555 fusing issue
    What sort of coverage is it? Are you using original toner? Have you tried setting the trays to a thick paper setting to ensure the machine slows down if coverage is overly heavy on thinner media?
    Hit it.
    • mikadonovan
      • May 2008
      • 2931
      An excellent question.
      NEVER ASSUME ANYTHING
      • TonerMunkeh
        Professional Moron
        • 3865
        On occasion I am known to ask a good one.
        Hit it.
        • KeviM
          • Oct 2019
          • 324
          • anothertech
            • 1766
            When you say the tech replace all the fusing parts, I'd be interested to know what parts were replaced, maybe not everything in the fuser was replaced.
            • Mark Bbb
              • Jun 2012
              • 1662
              could be that the pressure roller is not contacting the hot roller because the ball bearings of the PR is not in proper place.
