Ricoh 8100s Fuser Web consumption issue
  • rhpardo77
    • Dec 2019
    • 9
    Hello,
    I'm hoping someone can help me with this problem.
    I have a Ricoh 8100s that keeps using up a full fuser cleaning web in less than 30,000 impressions. I've made several adjustments to the web motor settings (SP 1902-002 & -003) to match the variations among my other machines, but that doesn't seem to make any difference. It's as if the web is constantly turning. Are there other setting I should be adjusting, or could there be something physically wrong with the motor?
    Thanks in advance for any suggestions!
    • 37488
    Re: Ricoh 8100s Fuser Web consumption issue
    Is the web supply roller pressure plate correctly installed?
    • rhpardo77
      • Dec 2019
      • 9
      It is. I just double-checked it now.
      I've even tried using the cleaning unit from another machine to test if there was an issue with the cleaning unit, itself, but the problem continues. That's what made me wonder if it was a motor issue, or a settings issue I overlooked.
        • 37488
        If the motor fails it doesn't run at all. Could be what ever board that drives the motor.
        • rhpardo77
          • Dec 2019
          • 9
          That's a good point! I hadn't considered the board. I'll look into that. Thanks for the suggestion!!
          • DRichard
            • May 2008
            • 482
            Also, check for a wire (to the motor) shorting/pinched/worn and touching a metal frame or bracket. This is something we have found on in the past.
            "Enjoy every sandwich."
            -- Warren Zevon
