Ricoh IM C2000 - Duplicated text
  • rich1106
    • Feb 2014
    • 21
    Hi everyone.
    I have a client with a new Ricoh IM C2000 (brand new, out of the box). He was printing with no problems when we install the machine but after around 1 month he call us because he was having a problem with the images he was printing, the text (white text) was duplicated all over the image (like faded text or something like that). I manage to fix this problem by calibrating the colors but it works for 2 days and the problem show up again. This machine has only 20k pages of work (color). What do you guys think could I do to fix this problem?
    I'll attach some photos so you guys can see what i'm talking about.
    Imgur: The magic of the Internet
    PS: Pardon my english.
  • dalewb74
    • Feb 2018
    • 1160
    Re: Ricoh IM C2000 - Duplicated text
    does it also occur if you print the same document on a different printer?
    • 8T2
      • Aug 2015
      • 257
      Do they usually print what is practically full bleed black background? Assume they do if it's how their menu looks. And that's not the ideal machine for that type of printing. Could be the black PCU failing, I'd swap the B and Y to test
      Sent from my WAS-LX1 using Tapatalk
      • ridgemill
        • Sep 2017
        • 190
        We've had the exact same issue on a IMC2500 (doing full colour images with repeated text shadowing), Ricoh says it is a limitation of the model; however you can decrease the transfer bias and increase the toner onto the page.
        This will mitigate the problem, however it will not be perfect, and the copier will use more toner to compensate.
        • yknot
          • Oct 2010
          • 5
          Originally posted by ridgemill
          we've had the exact same issue on a imc2500 (doing full colour images with repeated text shadowing), ricoh says it is a limitation of the model; however you can decrease the transfer bias and increase the toner onto the page.
          what are the sp modes to decrease bias and add toner
          • GIUBOSS
            • 1437
            ... start a new thread maybe with some pictures of the problem
            • Gift
              • Mar 2011
              • 2459
              Looks like a limitation to me - that "office color" print engine will not fullfill this "demands" to handle this inverted text&background scheme perfectly thanks to short diameter OPC drums.
              Try reducing the process speed by choosing the highest DPI setting + Quality settings in the driver or use thick paper with the approriate paper type setting, this "might" help and reduce this effect. I'd bet that this is noticeable with new parts, too - perhaps just more subtile.
